Author Topic: adding a turbo to a non turbo engine  (Read 3928 times)
March 22, 2005, 02:59:03 pm
KyleL
  • 11
« on: March 22, 2005, 02:59:03 pm »
I have heard that it is possible to add a turbo to a non turbo engine.
Is this true?  What does it involve?  Is it neccessary to change the entire head?  Would it be a lot more expensive to buy a non turbo and then add a turbo then to just but an engine that already has a turbo?
Thanks
Kyle La Ferriere
79 Westy (looking to convert to diesel or trade for diesel)
89 volvo 240dl wagon (looking to sell or trade for diesel)
Reply #1March 22, 2005, 03:08:41 pm
« Reply #1 on: March 22, 2005, 03:08:41 pm »
check the other posts, I'm sure someone has asked this before.
But to my knowledge, the only difference is the piston coolers.  (oil squirters on the block squirt oil onto the pistons to cool them)
Oh yea... You will either need a TD pump, or modify the one that you currently own.
Reply #2March 22, 2005, 03:09:29 pm
vwmike
  • 1158
Re: adding a turbo to a non turbo engine
« Reply #2 on: March 22, 2005, 03:09:29 pm »
Quote from: "KyleL"
Thanks
A lot of people will tell you that you can't turbo a non-turbo diesel. Obviously you physically can, but the engine won't hold up quite as well. The TD engine has oil squirters under the pistons and the head and valves are supposed to be made of a different alloy. That said, it will work, but you would especially need to keep a close tab on exhaust gas temperatures. You'd be more likely to hurt the engine when keeping it in boost for longer periods such as going up hills.
Reply #3March 22, 2005, 04:02:10 pm
« Reply #3 on: March 22, 2005, 04:02:10 pm »
yeah, intercooling would pretty much be a must, to keep EGT's down, and maybe a bigger downpipe, and run max 9 psi boost (or somewhere near there)
Reply #4March 22, 2005, 05:24:17 pm
vwmike
  • 1158
« Reply #4 on: March 22, 2005, 05:24:17 pm »
Try this thread and pay attention to what deo has to say- http://www.vwdiesel.net/phpBB/viewtopic.php?t=556&highlight=turbo
