Author Topic: Piston spacer shim (internal IP Q)  (Read 2856 times)
December 21, 2007, 06:34:51 pm
vanagonturbo
  • 639
    • Fine Tuning
« on: December 21, 2007, 06:34:51 pm »
Long story short, I need to replace the piston spacer shim in the pump head. The one that came out is 2.09mm thickness and the one I have is a 2.4mm thickness. Can I use this? Any negative effects? Thanks!
Reply #1December 22, 2007, 01:54:33 pm
oldskool rich
  • 446
« Reply #1 on: December 22, 2007, 01:54:33 pm »
ive not got years of experiance or a definate answer but in my mind id say that it wouldnt make any difference, the piston will still get the same distance of lift.
thats my opinion, assuming we are talking about the right part
if you want a real answer then just see how it runs :wink:
f6squared I.D.S.T
Reply #2December 22, 2007, 03:10:53 pm
Tintin
  • 1279
« Reply #2 on: December 22, 2007, 03:10:53 pm »
Remove the end cap plug on the head and measure the BDC (not TDC) of the plunger  + ou - 3.7mm is ok.
Reply #3December 22, 2007, 04:46:09 pm
Tintin
  • 1279
« Reply #3 on: December 22, 2007, 04:46:09 pm »
Between the face end of the plunger and the sealing face of the cap screw.
With the rear of the slide caliper It's easy.
Reply #4December 22, 2007, 08:04:18 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #4 on: December 22, 2007, 08:04:18 pm »
Quote from: "Tintin"
Thank you sir!
Reply #5December 23, 2007, 03:28:25 am
Jetman
  • 11
    • http://www.netikka.net/vepiku
« Reply #5 on: December 23, 2007, 03:28:25 am »
