Author Topic: i've looked  (Read 3633 times)
December 19, 2007, 02:09:27 pm
shegel
  • 312
i've looked
« on: December 19, 2007, 02:09:27 pm »
in the search area..with no luck....what exactly will start leaking if i run b100...what will i need to replace to run b100....we make it but the oterh diesels we have are newer than 93(93 was the year that viton lines and seals were used rather than traditional fuel line)
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
Reply #1December 19, 2007, 03:57:40 pm
BejamminR
  • 89
i've looked
« Reply #1 on: December 19, 2007, 03:57:40 pm »
Apologies for the spam, I posted this in an earlier thread today. Hope it answers your question!
Here's an earlier thread where it was talked about quite a bit:
100% Biodiesel / Seal Repercussions Thread
Reasonably Quick Answer: You may not need to replace anything. Then again, you might need to replace all of your seals and/or lines even if you just switch to ULSD, never mind biodiesel. If you are washing and neutralizing your biodiesel, it's possible that straight rubber lines will never have a problem. Get a jar of your B100 and throw a piece of fuel lines into it. Leave it there for months and months - it may never swell, crack, craze, anything. The seals could be a different story if you've run on Low Sulphur Diesel for a long time and are switching to Ultra Low Sulphur Diesel or Biodiesel - but it's not the B100 itself that tends to destroy seals or lines, strictly speaking. Viton is a good precaution, but may not be strictly necessary, depending on fuel quality.
Reply #2December 22, 2007, 09:37:39 pm
shegel
  • 312
i've looked
« Reply #2 on: December 22, 2007, 09:37:39 pm »
what seals typicly start leaking when using biodiesel
Reply #3December 22, 2007, 10:37:01 pm
i've looked
« Reply #3 on: December 22, 2007, 10:37:01 pm »
Let me answer by paraphrasing Benjammin:  none of them, or all of them !
Your current seals are likely all made of the same material... either they will handle the switch from whatever you're currently running to bio (and/or ULSD) or they won't.  If they do, no problem.  If they don't... they will all eventually go.  You'll replace one, and then the internal pump pressure will find the next one that's about to go.
IMHO, if you're planning to run B100 and you're worried about your seals... pull your pump, buy a 30 dollar complete seal kit, and do 'em all.  Otherwise, you'll find yourself doing one, and then another, and then another... if they start to leak at all.  Some of them require you to pull the pump anyway... and your odds of success are probably better doing them on a clean workbench.
Just my CDN $0.02...
Reply #4December 22, 2007, 11:41:42 pm
shegel
  • 312
i've looked
« Reply #4 on: December 22, 2007, 11:41:42 pm »
ok...so im gonna buy a kit just incase it does leak...but are there any other areas that will leak (or not leak) other than the pump and the fuel supply/return lines...injector seals?(if there arent then my bad)
Reply #5December 23, 2007, 04:22:19 pm
bigblockchev
  • 271
leaks
« Reply #5 on: December 23, 2007, 04:22:19 pm »
It will take a while for any leaks to show up in any case if they are caused by BD. I had my injector return lines leak after more than a year, replaced with Viton OK now. No injector seals leaking after more than 2 years. Cheers Dan
it's always something simple
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
