Author Topic: antivibration pulley position?  (Read 3626 times)
December 19, 2007, 03:05:20 am
haybayian
  • 155
« on: December 19, 2007, 03:05:20 am »
I am about to bolt on a new damper pulley and having never seen one before (and Haynes or Bentley not  being specific) I wonder if there is a right way or a wrong way to set it up.
Thanks for your guidance.
Haybayian
Keep it simple if you can.
Reply #1December 19, 2007, 03:31:10 am
MikkiJayne
  • 235
« Reply #1 on: December 19, 2007, 03:31:10 am »
It will only go on one way because of the bolt pattern. The four bolts in the crank sprocket are not equally spaced even though they might look that way with a quick glance.
There is also a pip on the sprocket with a matching hole on the damper so you can get it right first time.
Mikki x
