Author Topic: I wonder what it does.  (Read 4605 times)
March 21, 2005, 03:52:27 pm
shakakan
  • 20
« on: March 21, 2005, 03:52:27 pm »
Does anyone know what the small sillinoid looking thing between the injection pump and alternator does?  I am just wondering.
To be more specific, it is mounted directly in front of the injection pump, and has one small line bolted to the pump to the right of where the fuel enters from the filter.  It has one wire conected to it.  I belive it is red (the wire)  I am just wondering what it does.
Reply #1March 21, 2005, 04:48:40 pm
gropar
  • 49
« Reply #1 on: March 21, 2005, 04:48:40 pm »
I figure you a 1.9 engine. If it's the case, solenoid you are refering to is anti-polution device wich ajust injection timing (or volume -- not shure) according to engine revolution.
IF it is what you are refering to, it can be bypassed (continuous 12V through stop solenoid) to increase performance and fuel economy).
See with VWQ's Smog pump adjustment which you should be able to find here on VWdiesel.net.
1.9 IDI,
minimalist exhaust system; soon big FMIC and 15 psi boost.
Reply #2March 21, 2005, 04:50:57 pm
gropar
  • 49
« Reply #2 on: March 21, 2005, 04:50:57 pm »
1.9 IDI,
Reply #3March 21, 2005, 06:15:55 pm
shakakan
  • 20
« Reply #3 on: March 21, 2005, 06:15:55 pm »
I have a 1.6 NA (91 Jetta) it has the atmospheric compensator on top, if that makes a differenence.
Reply #4March 22, 2005, 03:36:11 pm
shakakan
  • 20
« Reply #4 on: March 22, 2005, 03:36:11 pm »
anyone?
Reply #5March 22, 2005, 04:28:52 pm
gropar
  • 49
« Reply #5 on: March 22, 2005, 04:28:52 pm »
Sorry : if it is a 1.6, then you lost me -- I do not have a clue about what it could be.
Maybe a picture would help.
1.9 IDI,
Reply #6March 22, 2005, 05:56:49 pm
« Reply #6 on: March 22, 2005, 05:56:49 pm »
thats not the fuel cut off solenoid is it???
Reply #7March 22, 2005, 08:48:48 pm
shakakan
  • 20
« Reply #7 on: March 22, 2005, 08:48:48 pm »
nope, the cut off solenoid is on the right side top of the pump.
Reply #8March 23, 2005, 09:19:22 pm
moosiah
  • 106
thing on inj pump
« Reply #8 on: March 23, 2005, 09:19:22 pm »
Hi the thing on the inj pump w the single wire hook up I've been told is a cold start advance control device........  :D  :( it takes the place of the pull cable in the dash
'81 Frankenbunny: part rabbit, sirroco, golf ,caddy cabrio ,jedda and ! ford teimpo! w a little more Audi and soon some Peogeot too!!!!
Reply #9March 23, 2005, 09:44:25 pm
dieseltech
  • 129
    • http://www.geocities.com/dean16v/Page_One.html
Re: thing on inj pump
« Reply #9 on: March 23, 2005, 09:44:25 pm »
Quote from: "moosiah"
then why is there still a pull cable on the dash, my 89 has that solinoid and the cable non turbo 1.6
86 td jetta power everything dd (update off the road for major resto).  97tdi bare bones, DD
and a private junkyard of various other vw/audi/bmw/peugeot/volvo/toyota diesels!!!
Cummins has the worlds record for being the most efficient engine ever!!!!!
for converting fuel into noise!
Reply #10March 24, 2005, 05:38:02 am
Mikeyworks
  • 260
    • http://www28.brinkster.com/mikeyworks/
« Reply #10 on: March 24, 2005, 05:38:02 am »
can you snap a picture and e-mail it or post it?
That would help a bunch.
Mikey
Reply #11March 24, 2005, 08:50:19 am
Mark(The Miser)UK
  • 1557
Re: I wonder what it does.
« Reply #11 on: March 24, 2005, 08:50:19 am »
Quote from: "shakakan"
 :?: Purely a guess but it sounds like an automatic choke similar t oone my father has on his Citroen.  Or is it a fuel preheater too :?:
Mark-The-Miser-UK
Reply #12March 24, 2005, 03:54:58 pm
dieseltech
  • 129
« Reply #12 on: March 24, 2005, 03:54:58 pm »
looks to me like its a timing retard device. it only gets power when its cold. when the engine warms up the +12v goes away
