Author Topic: my aaz fuel pump mods not woking, need help, please  (Read 6682 times)
Reply #15December 19, 2007, 01:18:51 pm
rubadubdub
  • 109
« Reply #15 on: December 19, 2007, 01:18:51 pm »
Ive got a dial gauge, pump and camshaft locking tools if you want to borrow them. I'm on Allesley Old Road in Coventry. I bought them to do the timing belt on my GTD so seeing as you've got a GTD pump they should work.
I warn you I've never done it before but theres loads of info on here and in the bentley so between us, the internet and the books we should be able to work out what the timing's set at.
Ive pm'd you my mobile number so you can get in touch if need be.
1991 Mk2 Golf GTD
Reply #16December 19, 2007, 06:55:57 pm
oldskool rich
  • 446
« Reply #16 on: December 19, 2007, 06:55:57 pm »
thanx mate whats the chances of that, im in walsgrave, i know allesley, wud be amazing if i cud borrow it mate, went to change back to my old camplate and found that the afn is 0.58mm too wide to fit in, so im getting it machined tomoz, as soon as i get it running ill giv you a call
thanx again blood, thats very helpfull :wink:
f6squared I.D.S.T
Reply #17December 21, 2007, 09:09:47 am
oldskool rich
  • 446
« Reply #17 on: December 21, 2007, 09:09:47 am »
Quote from: "Tintin"
Replace your came plate by the TD one, and that will go much better, but not perfect, a 11mm request some adjustment.
i had to grind off half a mm to make my old cam plate fit the plunger
what "adjustments" will i need to make btw? im installing the the pump tomoz.
also does anyone know if its worth running these 1.6 n/a injectors? or shud i stick with the aaz ones, seen a few other powerful diesels running them, just thort id copy
f6squared I.D.S.T
