Author Topic: oil pressure sending units. Please school me.  (Read 2400 times)
December 15, 2007, 02:22:22 pm
haybayian
  • 155
« on: December 15, 2007, 02:22:22 pm »
I am putting together a AAZ from a long block and I could use your guidance. At this point I am looking at  my instruments and the first ones I would like to set up  are  the oil pressure ones. I would like to hear your advice on where I should set up my sending units and where to buy the said units. What I have in mind is to keep the (low pressure ?) unit which I think is on the filter cap and add  a low/high pressure one  somewhere else. What should I do?
Thanks for your time.
Haybayian
Keep it simple if you can.
Reply #1December 15, 2007, 05:23:56 pm
Quantum TD
  • 1195
« Reply #1 on: December 15, 2007, 05:23:56 pm »
If you're planning on using a VDO 2 1/16 round gauges, why not just put it where the stock ones go on a Cabriolet. So, you'd use the stock pressure gauge on the oil pickup flange, and the VDO sending unit on the side of the head for the idiot light and the wire for the gauge.
Its really easy to do. I put some Cabriolet gauges on my 1984 Rabbit 1.6D, and the block/head is the same.
If you need a sending unit, I think I have about a half a dozen laying around here. They're the 1-5 bar type.
You can find used gauge sets on ebay all the time (I sell them there), or buy spiffy new ones at Summit Racing. The gagues are usualy cheap, it's the senders that are pricey. Here's a link for the sender:
http://www2.discountvdubparts.com/parts/parts1/discountvdubparts/quote.jsp?year=1986&product=P4030-36398&application=000194279&part=Oil%20Pressure%20Sender&category=P&returnurl=null&dp=false
 If you want a used 1-5 Bar sender for the gauge, then it'll be about $20 plus ship ($2-3 in the US).
Good Luck
Reply #2December 15, 2007, 06:20:24 pm
jasonsansfleece
  • 162
« Reply #2 on: December 15, 2007, 06:20:24 pm »
Here's another link
http://www.egauges.com/vd2_main.asp
And
http://www.egauges.com/vdo_send.asp?Sender=80PSI_5Bar_VDO
I'm using an 80 lbs gauge and sender #360-006
Guy
Reply #3December 16, 2007, 06:06:01 am
haybayian
  • 155
« Reply #3 on: December 16, 2007, 06:06:01 am »
Quote from: "jasonsansfleece"
Here's another link
And
Guy
Thanks Quantum and Guy,
Haybayian
Reply #4December 16, 2007, 08:02:21 pm
rallydiesel
  • 1880
« Reply #4 on: December 16, 2007, 08:02:21 pm »
Go with 80 PSI units. I had a 150 PSI and there is no point in having a gauge that goes that high in a diesel.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
