Author Topic: cleaning out injectors  (Read 7718 times)
December 12, 2007, 02:43:45 pm
« on: December 12, 2007, 02:43:45 pm »
My "new" used TDI injectors have lots of red gooey crap in them. What is the best thing to dissolve this stuff?
Reply #1December 12, 2007, 03:08:04 pm
Slave2School
  • 531
« Reply #1 on: December 12, 2007, 03:08:04 pm »
I've used an acetone bath to clean up injectors, seemed to work well.
2002 ford focme wagon
Reply #2December 15, 2007, 04:48:57 am
Baselyne
presurvation
« Reply #2 on: December 15, 2007, 04:48:57 am »
I may be totaly wrong but isnt it just trani fluid to keep them from siezing/corroding and rusting?
Used parts that I have bought for a fuel system always get the trani fluid fill to presurve them....
My CIS fuel pump did anyways....that *** will just burn off first crank....and im also told that trani fluid in the cilinder will slow down lost compression due to worn rings and such.....
i may be way out in left field but .......meh
someone to clear this up for us? please chime in....
Reply #3December 15, 2007, 07:53:24 am
« Reply #3 on: December 15, 2007, 07:53:24 am »
Giles said it sounded like veggie oil. It has a consistency of dried silicone, so isn't coming out on its own. I bought a can of nasty carb dip, and have one that's been sitting in it a few days. I'll probably look at it today. Even if I can't get them clean, Giles was going to throw them in an ultrasonic cleaner and check them out when I get around to sending my pump in.
Reply #4December 16, 2007, 09:54:38 am
Baselyne
injection persurving compound?
« Reply #4 on: December 16, 2007, 09:54:38 am »
So Im guessing this is a presurvation compound or? Like is this a comman problem for used injectors?
Where did these injectors come from?
It's great to know, as it could have been my injectors and id of never knew what to do...
Jimfoo wrote: "I bought a can of nasty carb dip, and have one that's been sitting in it a few days. I'll probably look at it today."
Once you had time to look please post what the results were and if it worked what brand of nasty carb dip did you buy?
Reply #5December 16, 2007, 12:34:55 pm
« Reply #5 on: December 16, 2007, 12:34:55 pm »
I think the injectors had just been sitting a long time, and the stuff turned to goo. The stuff I am using is Berryman Chem-Dip carburettor and parts cleaner. It's a 1 gal can with a basket inside. It is nasty stuff, so be sure to use gloves & goggles. It seems to work fairly well. I took one injector as far apart as I could and left it in for a few days. Before, the nozzle was completely clogged, now it's almost totally clear, The gooey stuff on the spring that I got out is gone. I was able to get the second spring and shim out after the first soak, but they are still covered, probably because the cleaner couldn't get to them well, so I am re-soaking them.
Reply #6December 30, 2007, 01:35:37 pm
  • 1739
« Reply #6 on: December 30, 2007, 01:35:37 pm »
i had some veg oil valves that had been sitting for a while and were completely gummed up. i tried biodiesel, diesel, gasoline[!]. finally the only thing that worked was brake fliud. cleaned them like new. it's also what we used to clean old carbs that had been sitting for a long time.
Reply #7December 30, 2007, 04:24:04 pm
subsonic
  • 1836
« Reply #7 on: December 30, 2007, 04:24:04 pm »
So does anyone have any suggestions for injectors or IP's that will be sitting for a while?  What will keep them fresh and ready to go?
Reply #8December 30, 2007, 04:39:21 pm
« Reply #8 on: December 30, 2007, 04:39:21 pm »
I'd say ATF as I don't think it has any shelf life, or maybe thin motor oil or lamp oil.
Reply #9December 30, 2007, 06:10:58 pm
« Reply #9 on: December 30, 2007, 06:10:58 pm »
Quote from: "the caveman"
yea brake fluid is some real nasty stuff! but you need something tough to get something tough out... instead of fighting fire with fire, you're fighting fire with explosives, which works quite well  :lol:
Reply #10December 30, 2007, 08:26:16 pm
  • 1739
« Reply #10 on: December 30, 2007, 08:26:16 pm »
definitally atf to preserve them.
