Author Topic: Took my head off, a couple questions now  (Read 4564 times)
December 11, 2007, 07:58:56 pm
hamradio
  • 282
« on: December 11, 2007, 07:58:56 pm »
Hi,
I removed my head tonight on my 1.6na, due to a kind of blown head gasket.
First question-
Antifreeze coming out was kind of a nasty dark greenish brown.  Could the blown hg have had a part in this, or is it just really crappy old antifreeze?
When I pulled the head off, a little road grime dirt kind of stuff fell in the cylinders.  Any tips of cleaning this out?
Why did some pistons have varying levels of soot on them?  One piston (#2) was relatively clean, and I could see the machining marks a little, but #1 was pretty sooty and dirty.
Reply #1December 11, 2007, 08:09:29 pm
« Reply #1 on: December 11, 2007, 08:09:29 pm »
The cylinders that are clean possibly had coolant leaking into them and they have been steam cleaned. It could be a sign of bad injectors, bad rings (low compression, poor burn) and a slew of other things
Compressed air will get the grime out of there
Reply #2December 11, 2007, 08:35:23 pm
MaxHedrm
  • 114
    • blog
« Reply #2 on: December 11, 2007, 08:35:23 pm »
Was the antifreeze kind of greasy too? Or just discolored? Mine was really nasty & full of emulsified diesel fuel & oil. Sort of a nasty black sludge.
DRIVE: 2010 Golf TDI
DRIVE (less): 2001 TT Roadster
Reply #3December 11, 2007, 08:58:12 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #3 on: December 11, 2007, 08:58:12 pm »
what they said. get your injectors pop tested while you have the head off. its a good precaution. slimy coolant is usually the result of a blown headgasket.
OT, you cant have a username of Hamradio and not post your callsign in the sig or something. its just not right. KB7MRM here.
Reply #4December 11, 2007, 10:25:33 pm
MaxHedrm
  • 114
    • blog
« Reply #4 on: December 11, 2007, 10:25:33 pm »
<==  KB5UZB
Thinking I might finally get a radio for the Jetta. The TT would look odd with antennas.  :wink:
Reply #5December 11, 2007, 11:42:15 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #5 on: December 11, 2007, 11:42:15 pm »
yeah, that could be odd. but then again, we are into Diesels :D My Vanagon looks better with antennas :D
Sorry about the thread jacking. Its the Op's fault for not posting a callsign ;)
Reply #6December 12, 2007, 04:55:32 am
« Reply #6 on: December 12, 2007, 04:55:32 am »
If the coolant/fuel/oil antifreeze sat in the engine for a long time you may want to do the bearings while you are in there. There is a good chance they are etched, especially if the car was driven under these conditions
Reply #7December 12, 2007, 05:00:42 am
hamradio
  • 282
« Reply #7 on: December 12, 2007, 05:00:42 am »
The main bearings?  I dunno, I guess.  But, hell, as long as I was doing those, I might as well re ring it.
Also,
I'm KC0KBH.
Reply #8December 12, 2007, 05:02:15 am
hamradio
  • 282
« Reply #8 on: December 12, 2007, 05:02:15 am »
Also, how much does it cost to get the injectors pop tested?  A local shop was quoting me somewhere around like $50/injector to test them.  Brand new injectors are $50, from what I am seeing.
Reply #9December 12, 2007, 05:41:21 am
njj_502
  • 24
« Reply #9 on: December 12, 2007, 05:41:21 am »
The fuel shop at my local CAT dealer quoted me $40 to pop test all 4 injectors.  $40 is cheap insurance to know if your units are up to snuff.  I've seen injectors on autohausaz.com for something like $34 each but not sure who is remanufacturing them (Bosch or xyz injection shop).
86 Golf IDI NA - Third owner as of 4/07... MINT
