Author Topic: darn 5sp linkages!!  (Read 2989 times)
December 11, 2007, 04:54:45 pm
vegfuel
  • 125
darn 5sp linkages!!
« on: December 11, 2007, 04:54:45 pm »
Waiting for my rebuild kit to arrive in the mail, I am hooking up the linkages to the 5spd I installed last summer on my 81' Rabbit. So it went pretty straight forward until I climbed in the cab and did some shifting. I can find all the gears except 5th :? . Some of the linkages I used were from the 4spd I had before. Maybe it's the base linkage to the shifter?
1986 Golf WVO converted.
Reply #1December 11, 2007, 05:02:25 pm
ilomax
  • 86
darn 5sp linkages!!
« Reply #1 on: December 11, 2007, 05:02:25 pm »
I did this in one of my older gasser Rabbits.
Push down (like you are going into reverse) and try to get into 5th.
You got some 4 speed parts left and they don't like to play together.
2001 Audi A8L - Air Ride Suspension - Car PC - 19" Work Equipped Euroline DH - For Sale / $18,000.
1984 Rabbit - Daily driver smoke machine - Can't complain about 23 year old technology that gets 45 MPG.
Reply #2December 11, 2007, 05:26:23 pm
lyeinyoureye
  • 96
darn 5sp linkages!!
« Reply #2 on: December 11, 2007, 05:26:23 pm »
Did you adjust the stop gap again?
Reply #3December 11, 2007, 06:34:59 pm
darn 5sp linkages!!
« Reply #3 on: December 11, 2007, 06:34:59 pm »
I did the 4-5 speed conversion on my rabbit, I hated it.
The stop gap probably needs to be adjusted a bit more.
What pieces did you change?
Reply #4December 11, 2007, 07:19:45 pm
gldgti
  • 488
    • http://scramjetsite.8m.com
darn 5sp linkages!!
« Reply #4 on: December 11, 2007, 07:19:45 pm »
a good trick i found is to turn the bell crank (called relay lever in the picture above)  on the gearbox housing upside down so you swap the long and short sides - this gives you more throw and a tighter feel. you need to twist one end of the short socket ended rod around 180deg, easy to do with a vice and adjustable spanner.
'91 Golf Cabrio 1.9TD
Reply #5December 12, 2007, 11:28:32 am
vegfuel
  • 125
darn 5sp linkages!!
« Reply #5 on: December 12, 2007, 11:28:32 am »
I can't really remember which pieces went to the 4spd or the 5spd. I am going back up to the 80' Rabbit gasser that I got the tranny off of and getting somemore parts. I guess was kind of lazy about this by just leaving the 4spd connections. I am thinking about just getting the whole sheebang.
how would i adjust the stop gap?
