Author Topic: Waiste gated  (Read 8222 times)
Reply #15July 24, 2008, 08:20:53 am
Darkness_is_spreading
  • 288
« Reply #15 on: July 24, 2008, 08:20:53 am »
I am considering the options of adding a BOV based on the issues of compressor surge because I have a Hybird turbo that I have built and am worried about surging the compressor vanes.....
I have been doing some reading and yes gas turbo cars need BOV because of throttle plate ( or massive loss in airflow)....  Air has no were to go and needs to be vented, isn't this the same  case  if your running up the gears and hit 22 PSI and then say you need to let off or need to engine break ( were does the excess boost go)......
I am setting my wastegate to open around 22-25 psi, but I am worried that if the exhast impellar is unloaded(wastegate open) and the compressor  still having the left over boost is still loaded may surge.
So if I tap into the wastegate line which senses compressor pressure and run a line to the wastgate, they should open simultaneously, allowing the turbo to have a balanced amount of pressure between the compressor and impellar.....
92 Jetta 1.6 T (Sleepin)
Reply #16July 24, 2008, 10:01:19 am
gigaz2
  • 626
Waiste gated
« Reply #16 on: July 24, 2008, 10:01:19 am »
but... thats how wastegated turbos regulate pressure already...
they surge because of the inertia of the spinning parts, ant the time it takes the wastegate to actually move and let the exhaust gasses out.
they only surge for that brief period of time, but bad things happen quickly :(
Reply #17July 24, 2008, 11:51:41 am
OM617
Re: .....
« Reply #17 on: July 24, 2008, 11:51:41 am »
Quote from: "Darkness_is_spreading"
Through the engine, there is no throttle to block airflow.
Reply #18July 24, 2008, 12:05:09 pm
Waiste gated
« Reply #18 on: July 24, 2008, 12:05:09 pm »
i would imagine that boost would also leak past the compressor wheel as it spools down... a BOV couldn't hurt anything though... except your wallet  :lol:
Reply #19July 25, 2008, 01:05:10 pm
dillenger1
  • 777
Waiste gated
« Reply #19 on: July 25, 2008, 01:05:10 pm »
I have a k26 from i believe an audi 5000 .it doesnt have a wastegate.At least on the exhaust housing.Would there be problems with running a bov in replace of a waistgate to regulate boost?
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #20July 27, 2008, 03:22:34 pm
OM617
Waiste gated
« Reply #20 on: July 27, 2008, 03:22:34 pm »
Quote from: "dillenger1"
Yes, the compressor wheel would explode when it overspeeds.
Reply #21July 28, 2008, 03:18:16 am
dillenger1
  • 777
Waiste gated
« Reply #21 on: July 28, 2008, 03:18:16 am »
Not to thread jack,but does anyone know why these(k26)didnt have a waistegate?Could it have been on the manifold some how.I dont see a pressure line anywhere on the compressor?
Reply #22July 28, 2008, 03:55:40 am
MJF
  • 581
Waiste gated
« Reply #22 on: July 28, 2008, 03:55:40 am »
5cyl gasser Audis have external wastegate.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #23August 02, 2008, 01:09:54 am
  • 3468
    • McScrubbins Body Wash
Waiste gated
« Reply #23 on: August 02, 2008, 01:09:54 am »
Well....
i plugged mine with a cork and she FLIES now. especially with more fuel and massive downpipe and no cat or muffler just 3 inch pipe. watch that egt though
Reply #24August 02, 2008, 06:18:06 am
foxracer1
  • 991
Waiste gated
« Reply #24 on: August 02, 2008, 06:18:06 am »
It seems the factory setup would sacrafice the turbo to save the engine. ie. headgasket, maybe rods. In the event of a wastgate failure.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #25August 02, 2008, 10:40:11 am
OM617
Waiste gated
« Reply #25 on: August 02, 2008, 10:40:11 am »
It looks that way.
