While the bentley manual may state that the cam locking tool should remain in place and take the torque of tightening the bolt, chances are good that you will break the cam if you do this. I've seen it happen many times. Some aftermarket manuals do suggest the use of a counterhold tool to avoid breaking the cam, though the bentley does not. It's ultimately your choice I guess...
The slot can hold the required torque to tighten the cam bolt guys. It's not a whole lot... 35-ft lbs, IIRC. I don't believe that anyone following the Bentley procedure for tightening this bolt while using a torque wrench going only to 35 ft-lbs will break their cam slot. And after trying other methods of tightening without the cam slot locked, I found the timing moved during tightening. I will be sticking to the Bentley procedure.I am in agreement with you guys that the cam locking tool should not be used when loosening the bolt.
While you're right in theory (practice actually ;o) It is still a fact that I've come across more people with a broken cam slot than people who've been hit by trees with rotten middles...
QuoteWhile you're right in theory (practice actually ;o) It is still a fact that I've come across more people with a broken cam slot than people who've been hit by trees with rotten middles... Nearly everytime I read one of your posts I nearly pi$$ myself laughing. Only a brit could come up with a bit like that... :lol:Thank you for being a source of comic relief in my otherwise dull day of PLC programming...
The missus still doesnt see the attraction of diesel and mathematics
QuoteThe missus still doesnt see the attraction of diesel and mathematics Odd, that. Seems to be the same the world over. Perhaps they all share the same brain?
No, some just share a common hormone that seems to block logical thought. :roll:
:QuoteNo, some just share a common hormone that seems to block logical thought. :roll: I can't agree Mike:twisted: I look at Mary and I just think multiple NAND gate :evil:
