Author Topic: one hole vs two hole head gasket ?  (Read 4136 times)
December 06, 2007, 07:47:20 am
giulianot
  • 146
« on: December 06, 2007, 07:47:20 am »
How much of a drop in compression would i see if i put a two hole head gastket in the place of a one hole headgasket?  The difference is only .04 mm but what does that equate to in drop in compression? Is the difference so little that i wont even notice it on cold starts? anyone done this before?
1990 cabriolet 1.9 aaz, kkk 24/26,  Giles pump, big  2.5" intercooler,  3 " P.P. downpipe
Reply #1December 06, 2007, 08:08:06 am
« Reply #1 on: December 06, 2007, 08:08:06 am »
I really doubt you'd notice anything at all.
Reply #2December 06, 2007, 09:26:01 am
« Reply #2 on: December 06, 2007, 09:26:01 am »
if it got really cold you might notice it a little.  otherwise you won't notice it at all above 0 deg C unless you have bad compression.
Reply #3December 06, 2007, 09:44:28 am
shegel
  • 312
« Reply #3 on: December 06, 2007, 09:44:28 am »
if you had a td then could you run the thicker gasket and then up the boost/fuel
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
Reply #4December 06, 2007, 10:06:11 am
« Reply #4 on: December 06, 2007, 10:06:11 am »
Quote from: "shegel"
but this won't really help those subzero cold starts...  great for a summer hot rod though  :twisted:
Reply #5December 06, 2007, 10:58:04 am
shegel
  • 312
« Reply #5 on: December 06, 2007, 10:58:04 am »
it doesnt get that cold here though....is it comparable to the compression loss that results from using the 1.9 head on the 1.6 block
Reply #6December 06, 2007, 11:35:32 am
giulianot
  • 146
« Reply #6 on: December 06, 2007, 11:35:32 am »
Up here in the great white north we see temps as low as -30 deg c , my application is on a 1.9 aaz the old gasket after 300 km use :roll: here are some pics of my burnt one hole headgasket.  :x
Reply #7December 06, 2007, 11:37:28 am
« Reply #7 on: December 06, 2007, 11:37:28 am »
Are 1 holes just not available? You could always get the block skimmed a little for the 2 hole.
Reply #8December 06, 2007, 12:05:50 pm
giulianot
  • 146
« Reply #8 on: December 06, 2007, 12:05:50 pm »
Auto-camping only has 2 hole victor rienz in stock and 1 hole elna head gasket. I've never heard of elna, are they a reputable manufacturer? I wanted to use a 2 hole gasket  thinking that it might eliminate haed gasket failure under high boost. Is thinking correct?
Reply #9December 06, 2007, 02:11:25 pm
Reply #10December 06, 2007, 09:29:05 pm
« Reply #10 on: December 06, 2007, 09:29:05 pm »
Quote from: "giulianot"
it might not eliminate hg failures, but it will surely reduce the possibility of them occuring.
the only reason these motors have such high compression is for cold starts.  you could probably get away with 300 psi compression or maybe even a bit lower if the car was started at full operating temperature.
it has been stated before in some threads that using a thicker hg to decrease compression isn't a wise idea as it changes something to do with injector spray pattern in the piston reliefs or something like that... i have a huge headache otherwise i'd remember.
Reply #11December 07, 2007, 08:35:30 am
fastvicar
  • 154
« Reply #11 on: December 07, 2007, 08:35:30 am »
What about the 3-notch one?
1981 Rabbit 1.6L TURBO!!  "The Whistle Pig"
