1.6na
Topic: 1.6na (Read 2707 times)
December 03, 2007, 02:00:30 pm
shegel
1.6na
December 03, 2007, 02:00:30 pm »
what is involved in a rebuild. im planning on doing the head and rings but im not sure on anything else....im going to be rebuilding it with my dad or uncle. so unexperience is not an issue on their end. whattl happen is i'll be doing the work but they will be double/tripple checking it...can i some how make the na engine turbo-able or some way to make the car go a little better up hills. right now i cant hardly hold it in 5th gear going up some grades that are no problem for my ghia and its got 40hp engine with only slight upgrades
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
December 03, 2007, 02:37:34 pm
1.6na
December 03, 2007, 02:37:34 pm »
Start with a compression test. It easily could be the injection pump that needs to be rebuilt (and or injectors) and not the engine
December 03, 2007, 09:00:27 pm
shegel
1.6na
December 03, 2007, 09:00:27 pm »
ok...how much are those ...and where can i get one
December 03, 2007, 09:31:24 pm
1.6na
December 03, 2007, 09:31:24 pm »
cheap compression testers can be found on ebay. use search words: vw diesel compression tester or a combination. just make sure its compatible with vw.
www.dieselvw.com
sells injectors for turbo motors... they have a higher breaking pressure than NA injectors but the price is unbelievable.
getting the injectors out is a whole other story. spray them with some penetrant a few times a day. before and after trips helps a lot.
December 04, 2007, 07:29:53 am
fastvicar
1.6na
December 04, 2007, 07:29:53 am »
Anyone have any experience with
www.dieselvw.com
? His prices just seem too good to be true. :?
1981 Rabbit 1.6L TURBO!! "The Whistle Pig"
December 04, 2007, 07:33:32 am
1.6na
December 04, 2007, 07:33:32 am »
Same as e-miata.com, injection pump.com, TDI-parts.com, volkswaparts.com....... I have only bought injection pump tools from him.
December 04, 2007, 08:01:52 am
1.6na
December 04, 2007, 08:01:52 am »
To be honest, I am probably buying my TDI pistons from them, though I'm going to see if I can get them without the rings. Cheap pistons might be one thing, but cheap rings are another.
December 04, 2007, 08:28:42 am
1.6na
December 04, 2007, 08:28:42 am »
Quote from: "fastvicar"
www.dieselvw.com
I think he is in Germany til the end of this week.
just a FYI.
1.6na
