Author Topic: Converted samurai is cold-blooded  (Read 4279 times)
December 03, 2007, 05:54:48 am
addautomotive
« on: December 03, 2007, 05:54:48 am »
Starts like a champ all summer long. Once it's -10, I have to beat on it mercilessly to start it.
New starter
New 850cca battery
4 good glow plugs
It spins FAST, and pounds on one or two cylinders JUST LIKE it has bad glow plugs... but it doesn't.
EXCEPT... it burns a couple glow plugs every month or two.
This is the second year of this madness, I just can't figure it out.
Ideers?
Reply #1December 03, 2007, 08:25:26 am
Zulfiqar
  • 254
« Reply #1 on: December 03, 2007, 08:25:26 am »
too much oil consumption
bad quality plugs
bad injector spray pattern (most likely)
GP circuit not doing correct job.
check these - any diesel will react to cold temps but eating GPs is bad news
Diesel IS the future
Reply #2December 03, 2007, 08:38:23 am
addautomotive
« Reply #2 on: December 03, 2007, 08:38:23 am »
The glow plug circuit is working fine... I use a ford solenoid and a momentary switch. Even if I give them 15 seconds it wont start well.
Would bad injectors perform worse in the cold?
Who is rebuilding injectors? I have a spare set I can send out.
Reply #3December 03, 2007, 11:08:08 am
addautomotive
« Reply #3 on: December 03, 2007, 11:08:08 am »
just spoke with the local VW shop... they also said that I should double check my cam & IP timing. They said it sounds like retarded timing, because I also noted hazy exhaust and poor turbo spool up.
Reply #4December 03, 2007, 11:11:24 am
Zulfiqar
  • 254
« Reply #4 on: December 03, 2007, 11:11:24 am »
your best investment would be a dialgauge and camlock tool - best money ever spent for me.
have any diesel shop check your injectors - just get a reputable one to test them like the manual says - not pumping the living daylights out of them.
