Author Topic: new 1.6 injectors and nozzles in 1.9 aaz - OK?  (Read 2442 times)
December 01, 2007, 04:01:14 pm
ricosuave
  • 244
« on: December 01, 2007, 04:01:14 pm »
the search function didn't help me out, need an answer fairly soon...
thinking of replacing my stock aaz 1.9 injectors with a set of 1.6 ones, they have KCA30S36/4 stamped on them and are bosch remanufactured...
any insight would be helpful - will i have any issues?
Reply #1December 01, 2007, 05:10:14 pm
QuickTD
  • 1156
« Reply #1 on: December 01, 2007, 05:10:14 pm »
The 1.9 lines won't fit properly. The 1.9 injectors are 2 stage and have longer bodies to house the 2 spring mechanism, the 1.6 injectors are about 3/4" (20mm) shorter. You can bend the 1.9 lines to fit but there is some risk of the lines cracking. I think a set of 1.6 lines will fit, but they'll still require some bending, less than the 1.9 lines though.
 I don't forsee any issues with using single spring nozzles, maybe a slight increase in engine noise.
Reply #2December 01, 2007, 09:23:51 pm
ricosuave
  • 244
« Reply #2 on: December 01, 2007, 09:23:51 pm »
ah crap, well thanks anyway quicktd
Reply #3December 03, 2007, 02:22:50 pm
QuickTD
  • 1156
« Reply #3 on: December 03, 2007, 02:22:50 pm »
No need to scrap the plan, the 1.9 lines are just difficult to fit with short injectors. Just get a set of 1.6 lines and use them, they require some tweaking but not as major as the 1.9 lines.
