Author Topic: Can I use this Audi block?  (Read 2233 times)
November 30, 2007, 07:54:28 am
Vanagoner
  • 219
« on: November 30, 2007, 07:54:28 am »
I'm parting out a (free) '72 Audi Fox.  It is a 1500 gasser, 827 series engine block longitudinal.  Can I use the engine block as a basis for a 1.6 IDI build?
Sage
Reply #1November 30, 2007, 09:09:19 am
ilomax
  • 86
« Reply #1 on: November 30, 2007, 09:09:19 am »
Hmmm.......... Can you use a gasser block with diesel internals?
What are the differences?
Sorry for the partial thread jack, I'm interested as well!
2001 Audi A8L - Air Ride Suspension - Car PC - 19" Work Equipped Euroline DH - For Sale / $18,000.
1984 Rabbit - Daily driver smoke machine - Can't complain about 23 year old technology that gets 45 MPG.
Reply #2November 30, 2007, 09:15:44 am
Turbinepowered
  • 1206
« Reply #2 on: November 30, 2007, 09:15:44 am »
I dunno about the Audi Fox engines, but it's my understanding (supported by the Bentley for the Dasher) that the two engines used in the Dasher shared a block, the 1.5 diesel and the 1.6(?) gas engine.
You might be able to get away with it, but it's probably going to have the smaller head bolts (11mm) that were the source of many of the 1.5s problems with killing headgaskets, which in turn led to the upgrade to 12mm headbolts on the later 1.6 diesels.
Reply #3November 30, 2007, 09:22:46 am
Vanagoner
  • 219
« Reply #3 on: November 30, 2007, 09:22:46 am »
Ah- good point about the headbolts.  If the pitch is the same, I might drill & tap them to 12's.  How about oil galleys, main bearings, etc?  If it is too much hassle I won't bother, but so far, the price is right. :)
Sage
Reply #4November 30, 2007, 11:56:09 am
935racer
« Reply #4 on: November 30, 2007, 11:56:09 am »
That engine does have 11mm bolts, but the bigger issue is the lack of reinforcement that the diesel block has, the casting has more webbing around the bases of the cylinders and I assume is also likely thicker around the cylinders as well.
