Starting Issues - a new one
Topic: Starting Issues - a new one (Read 2609 times)
November 27, 2007, 11:36:21 pm
Cheesetoast
November 27, 2007, 11:36:21 pm »
i think i've got a glow plug or 2 that needs replacing, but this puzzles me. Starting when it's cold it'll crank a couple times then fire up no problem, but with some smoke and chugging for a few seconds, sounds like glow plugs to me. I drive the car for a bit and it warms up, i park it for a few minutes then start it again and it has to be cranked longer, takes about 6 -8 cranks to start when warm, why would this be?
1993 Golf 1.9TD
http://members.shaw.ca/adowler/
November 27, 2007, 11:39:44 pm
ilomax
November 27, 2007, 11:39:44 pm »
Mine does this sometimes as well.
Would be interesting to hear some ideas of what it might be.
2001 Audi A8L - Air Ride Suspension - Car PC - 19" Work Equipped Euroline DH - For Sale / $18,000.
1984 Rabbit - Daily driver smoke machine - Can't complain about 23 year old technology that gets 45 MPG.
November 28, 2007, 05:10:16 am
addautomotive
November 28, 2007, 05:10:16 am »
Sounds like air leaks in the fuel lines.
November 29, 2007, 10:37:24 pm
Cheesetoast
November 29, 2007, 10:37:24 pm »
fuel lines have barely any bubbles in em.
1993 Golf 1.9TD
November 29, 2007, 10:41:19 pm
ilomax
November 29, 2007, 10:41:19 pm »
I figured mine out.
Old crappy batter cables and power cables for the glow plugs.
My glow plugs actually work correctly and the car turns over quite fast.
The car starts better than ever.
November 29, 2007, 10:42:39 pm
November 29, 2007, 10:42:39 pm »
Sounds like your starter is not turning enough once it warms up. Check for voltage drops in the wires and if possible test the draw that the starter is creating or have it bench tested.
It could also be a faulty GO relay or GP temp sensor
November 29, 2007, 10:44:34 pm
Cheesetoast
November 29, 2007, 10:44:34 pm »
hmm, this is a new issue, and the starter was changed with the tranny. As was the battery, the one in there is junk, optima red top going in next week, i'll try that first and let you guys know.
1993 Golf 1.9TD
November 29, 2007, 10:45:35 pm
November 29, 2007, 10:45:35 pm »
changed doesn't necessarily mean better. Is it a new unit? The cables and connections could still be causing the problem
November 29, 2007, 10:47:35 pm
ilomax
November 29, 2007, 10:47:35 pm »
Proof right here!!!
Bad battery cables with give you troubles.
