Author Topic: ac removal.  (Read 2615 times)
November 27, 2007, 03:05:01 pm
shegel
  • 312
ac removal.
« on: November 27, 2007, 03:05:01 pm »
i want to take the ac pump off of my golf is there an easy way to do this and relocate the alternator where the ac pump was? the only reason im doing this is because the car no longer has a condenser and i dont plan on buying one.
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
Reply #1November 27, 2007, 05:36:45 pm
trent77
  • 217
ac removal.
« Reply #1 on: November 27, 2007, 05:36:45 pm »
click here
I hope this link works. there is a photo of an alt. bracket this person made. I made the same one, it worked perfectly. It even has dimensions. good luck!
PS I pm'd you, I think this link will be more than helpful.
91 (former)eco jetta now aaz (sold to Ben)
05 passat tdi (sold)
77 westfalia
06 GMC Duramax
10 Jetta sportwagen tdi
81 Rabbit pickup (Caddy)
Reply #2November 27, 2007, 05:59:41 pm
ac removal.
« Reply #2 on: November 27, 2007, 05:59:41 pm »
That is pretty much exactly how the stock non ac setup works. It is the exact same bracket as what you have but you need that lower bracket. It is diesel specific. Non ac and AC use the same main bracket but the smaller ones are different. You may need a different alt pulley.You can leave the alt where it is and just use a long belt but I wouldn't recommend that
Reply #3November 27, 2007, 11:06:52 pm
shegel
  • 312
ac removal.
« Reply #3 on: November 27, 2007, 11:06:52 pm »
i must be missing somthing...how is the belt tensioned?
Reply #4November 28, 2007, 01:07:45 pm
myke_w
  • 1099
ac removal.
« Reply #4 on: November 28, 2007, 01:07:45 pm »
what alternator does it use? is it same as gas?
