Author Topic: mechanical tdi almost ready  (Read 6620 times)
March 16, 2005, 05:06:39 pm
scopefrfd
  • 289
« on: March 16, 2005, 05:06:39 pm »
I have pics if anyone wants to host them
Reply #1March 16, 2005, 05:09:31 pm
dieselpower
  • 177
« Reply #1 on: March 16, 2005, 05:09:31 pm »
I can host them if you want. what parts did you use for your pump?
Mark
84 rabbit 1.6TD
because real cars don't have sparkplugs
Reply #2March 16, 2005, 06:02:22 pm
scopefrfd
  • 289
« Reply #2 on: March 16, 2005, 06:02:22 pm »
I beleive the pump is from a fiat on this particular engine. It's a 11mm pump.
Reply #3March 16, 2005, 06:53:14 pm
dieselpower
  • 177
« Reply #3 on: March 16, 2005, 06:53:14 pm »
here's the pics
lookin good so far, what kind of turbo is that?
Mark
84 rabbit 1.6TD
Reply #4March 16, 2005, 07:25:09 pm
scopefrfd
  • 289
« Reply #4 on: March 16, 2005, 07:25:09 pm »
the stock garrett from a 1.6td.  It has been rebuilt and ceramic coated along with the intake, exhaust manifolds, downpipe.
Reply #5March 17, 2005, 05:41:41 am
« Reply #5 on: March 17, 2005, 05:41:41 am »
NICE!  Any pump mods?  Where did you score the pump?  Any special injectors being used?  It will be interesting to see how the garrett performs.
What kind of car is it going in?
Good stuff.
84 Scirocco 8v
00 Camaro L36 M49
Reply #6March 17, 2005, 02:25:53 pm
scopefrfd
  • 289
« Reply #6 on: March 17, 2005, 02:25:53 pm »
Everything is stock right now just to get it running.  I set the pump at 1.00mm and I'm using the automatic tdi injectors as a baseline which have the smallest nozzles.  Turbo is also stock as far as the wastegate for now.
pump is from a fiat croma I believe.   the pump will be modded after everything is sorted.  Engine is going into a 92' jetta 2 door.  Intercooler will either be the factory GTD setup or a water to air intercooler.
I have injectors from a manual 1.9 tdi, and the bigger 2.5L tdi injectors.
I had to have a special spacer made for the injection pump.  I didn't get the sprocket with the pump.  Plus you really have to use the 2 piece sprocket with this setup as one of the pump bolts is blind once the sprocket is installed and it would be very difficult to tighten.
