Author Topic: Benefits of Gasser Intake on 1.6td  (Read 4282 times)
November 26, 2007, 09:26:07 am
CasualDays
  • 17
« on: November 26, 2007, 09:26:07 am »
How much difference does it make?
Is it worth the swap?
I'm going to renewing a few things on the 1.6td and I have a 1.8 intake from a JH laying around.
 :shock:
Do it Right or Do it Twice!
Reply #1November 26, 2007, 10:12:49 am
« Reply #1 on: November 26, 2007, 10:12:49 am »
you need to flip the exhaust manifold to make it fit.
The benefits are less cylinder bias (#2 and #3) get a lot more air then #1 and #4
This is assuming you have a TD, it it's NA there is no gains that I'm aware of
Reply #2November 26, 2007, 10:23:03 am
CasualDays
  • 17
« Reply #2 on: November 26, 2007, 10:23:03 am »
Quote from: "burn_your_money"
Well I do have a 1.6td.
So #2 and #3 get more air than 1 and 4?
Is that even beneficial for my diesel? :?:
Reply #3November 26, 2007, 10:25:05 am
« Reply #3 on: November 26, 2007, 10:25:05 am »
It's a lot of work. You'll need a new custom down pipe as well as oil feed and drain line. Plus the turbo needs to be clocked (rotated)
For stock power it's not worth it IMO
Reply #4November 26, 2007, 12:06:55 pm
cowboybootlegger
  • 26
« Reply #4 on: November 26, 2007, 12:06:55 pm »
I used an intake off a digifant Fox 1.7L, and had i not been using an aftermarket exhaust manifold, (designed for a gasser) and a different turbo, i would have just stuck with the stock intake.  Like burn_your_money said, it's alot of work unless you're going for big power, which in that case one of Dave's PP manifolds would be awesome! :lol:   I don't think they require the mods a gasser one does to install either.
Reply #5November 26, 2007, 12:20:02 pm
935racer
« Reply #5 on: November 26, 2007, 12:20:02 pm »
If your still using the stock o2o transmission you won't be able to make a really good downpipe with the stock manifold and turbo flipped upside down because the shift linkage is in the way. There are other options :wink:
Reply #6December 01, 2007, 07:55:11 am
CasualDays
  • 17
« Reply #6 on: December 01, 2007, 07:55:11 am »
Well, I am shooting for around 110whp so the question is..Do I need a gasser intake to make numbers like that?
Quote from: "cowboybootlegger"
Where would I find one of these Dave's PP manifolds?
Reply #7December 01, 2007, 08:09:58 am
« Reply #7 on: December 01, 2007, 08:09:58 am »
Quote from: "CasualDays"
Look up? :roll:
Reply #8December 01, 2007, 09:26:12 am
« Reply #8 on: December 01, 2007, 09:26:12 am »
you can make 110 whp with extra fueling, big intercooler and more boost. a larger downpipe would go a long way for the longetivity of the motor.
a better intake manifold will equalize the pressure and help keep your HG from blowing.  pulsed exhaust manifold will do the same, help your turbo spool better, and equalize the exhaust backpressure which can also lead to blown hg's etc.
Reply #9December 01, 2007, 09:33:44 am
CasualDays
  • 17
« Reply #9 on: December 01, 2007, 09:33:44 am »
Quote from: "jimfoo"
Look up? :roll:
Oh, I see  :D
Quote from: "jtanguay"
So, Dave's manifold would be choice then for longetivity and  reliability?
Reply #10December 03, 2007, 04:53:29 pm
CasualDays
  • 17
« Reply #10 on: December 03, 2007, 04:53:29 pm »
How much does  one of Dave's manifolds go for?
