Fixmyvw.com
Author Topic: IDI to TDI  (Read 48712 times)
Reply #75January 29, 2008, 03:22:21 pm
IDI to TDI
« Reply #75 on: January 29, 2008, 03:22:21 pm »
It's just too bad I won't have a before for reference. I figure they can't hurt anything ither than lowering the compression a tiny bit, which will probably be more than made up by the fact that the pistons are 1mm bigger and probably taller. Oh oh oh, my cranks done. Time for a trip...
Reply #76January 29, 2008, 03:45:00 pm
  • 9005
IDI to TDI
« Reply #76 on: January 29, 2008, 03:45:00 pm »
This is exciting stuff :D
Reply #77January 29, 2008, 06:09:01 pm
subsonic
  • 1836
IDI to TDI
« Reply #77 on: January 29, 2008, 06:09:01 pm »
Who did the coating?
Reply #78January 29, 2008, 06:17:55 pm
Slave2School
  • 531
IDI to TDI
« Reply #78 on: January 29, 2008, 06:17:55 pm »
Who did the grooving?  It doesn't look the same on both pistons.
2002 ford focme wagon
Reply #79January 29, 2008, 08:12:33 pm
IDI to TDI
« Reply #79 on: January 29, 2008, 08:12:33 pm »
Grooving, my bad as I did it. I doubt it is going to do that much, so I don't think a little difference will matter much. Coating by Pristine Powdercoating in Denver, $20 per piston. I put one piston in and measured protrusion, .8mm, so IT WILL WORK!!!, even the same size 2 notch gasket I had before.
Reply #80January 29, 2008, 09:01:21 pm
Slave2School
  • 531
IDI to TDI
« Reply #80 on: January 29, 2008, 09:01:21 pm »
I agree it will be interesting to be able to see the results.  I guess we'll have to wait a few years before transparent aluminum is developed :(
Reply #81January 29, 2008, 09:34:56 pm
IDI to TDI
« Reply #81 on: January 29, 2008, 09:34:56 pm »
Quote from: "Slave2School"
if they make glass that can withstand undersea pressures then they can make some for an engine.   :wink:  now building it is another story  :lol:
maybe some kind of small viewport?
Reply #82January 29, 2008, 09:52:49 pm
IDI to TDI
« Reply #82 on: January 29, 2008, 09:52:49 pm »
Maybe a diamond engine, if they can ever make ones that big. Won't wear and an excellent conductor of heat. You could get it faceted to pimp it, so it's all sparkly when it runs. :lol:  :lol:
Reply #83January 29, 2008, 11:50:33 pm
Slave2School
  • 531
IDI to TDI
« Reply #83 on: January 29, 2008, 11:50:33 pm »
Yes but you'd never find a grill with enough jewelry to compete...
well ok I guess I was wrong :D
Reply #84January 30, 2008, 08:55:51 am
subsonic
  • 1836
IDI to TDI
« Reply #84 on: January 30, 2008, 08:55:51 am »
P-I-M-P OLOGY :lol:
Reply #85February 01, 2008, 06:40:50 pm
IDI to TDI
« Reply #85 on: February 01, 2008, 06:40:50 pm »
Today it was barely warm enough to be able to paint, since I have to do it outside. So I gave the block a nice coat of Detroit Diesel Alpine Green as it is the closest to the stock Rover engine color.
I decided to paint the valve cover green too rather than leaving it the stock black. Pulleys however get black.
Or go here for the whole project so far.
Reply #86February 02, 2008, 04:57:54 am
MJF
  • 581
IDI to TDI
« Reply #86 on: February 02, 2008, 04:57:54 am »
Don´t you need TDI valve cover too?
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #87February 02, 2008, 09:20:13 am
IDI to TDI
« Reply #87 on: February 02, 2008, 09:20:13 am »
Damn, now that you mention it....
Reply #88February 02, 2008, 01:10:26 pm
Tintin
  • 1279
IDI to TDI
« Reply #88 on: February 02, 2008, 01:10:26 pm »
Jim, If you want, you can run your stock AAZ pump with a 10mm head if you have a 1996 and up AAZ pump for the proper came plate, that run better than just the stock AAZ pump, and PM me for the proper pressure regulator  to match the 10mm head on AAZ pump, you have one in your parts...  héhéhé!! just to know it is which  :wink:
That would be perfect to first run your engine, about 1000-1500miles, and later you will be able to make build a real M-pump.
Reply #89February 02, 2008, 01:52:49 pm
IDI to TDI
« Reply #89 on: February 02, 2008, 01:52:49 pm »
Thanks for the info. I am unsure exactly what year it is. It was supposed to be a 1996 engine, but it has the older style connecting rods, so it's a 1995 or older. I am going to send my pump to Giles soon as I only want the car down one time, plus it is much easier to time with the engine out.
