TDI Engine -General Info
TDI(-e) with vnt
Topic: TDI(-e) with vnt (Read 2793 times)
November 24, 2007, 02:50:26 pm
Benjamin
TDI(-e) with vnt
November 24, 2007, 02:50:26 pm »
guys,
is it possible to add a vnt turbo -pressurecontrolled- on a tdi wich have original a wastegated turbo?
or will the programm run into emergency becouse you cant control the pressure so good?
Greetz, Benjamin
Must make +250hp
November 24, 2007, 05:12:09 pm
MikkiJayne
TDI(-e) with vnt
November 24, 2007, 05:12:09 pm »
This is possible with some work.
You need to change the N75 valve to that from a VNT engine, and also change the software in your ECU to handle the VNT. For 1Z and AHU TDIs the software from the AFN can be used, or you can just use an AFN ECU if you have one.
Talk to Jeff at Rocketchip - he can do this for you
Mikki x
TDI(-e) with vnt
