Author Topic: What is this tool for?  (Read 3013 times)
November 23, 2007, 03:06:00 pm
« on: November 23, 2007, 03:06:00 pm »
http://cgi.ebay.com/ebaymotors/VW-TDI-3359-Diesel-Pump-Pin-Engine-Timing-Repair-Tool_W0QQcmdZViewItemQQcategoryZ35625QQihZ002QQitemZ4625726483QQrdZ1QQsspagenameZWD1V
Use to test ECO and TDI diesel pump timing on engines with a divided pump gear.
i guess its for electronic timing?
Reply #1November 23, 2007, 03:56:24 pm
andy2
« Reply #1 on: November 23, 2007, 03:56:24 pm »
Its used on 96-97 AAZ and ALH TDI to lock the inj pump for installing the timing belt.The 1Z and AHU TDI use the same pump lock tool as older diesels up to 95.
Reply #2December 05, 2007, 05:14:48 pm
HermTDI
  • 27
Re: What is this tool for?
« Reply #2 on: December 05, 2007, 05:14:48 pm »
Quote from: "jtanguay"
That pin is used to lock the cam sprocket on the PD engine. This is the same pin used to lock the injection pump sprocket on the ALH engine
