Author Topic: 1.6 wiring questions  (Read 4110 times)
November 23, 2007, 02:42:15 pm
2mAn
« on: November 23, 2007, 02:42:15 pm »
im putting everything back together and im a lil confused as to which wires go where. ive got 99% of it done, but i got 3 wires all going to the same area and not sure which goes where...
on the side of the head there is the coolant flange that has two areas where wires go across from each other. then there is also a sensor right above this flange.
the wires i have left are two yellow wires ( one is solid yellow, the other is yellow. red) and one blue/ white wire...
as far as i know the two yellow wires go on the coolant flange and the blue/ white is for the other sensor. can anyone confirm this?! thanks in advance
Reply #1November 23, 2007, 02:49:48 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #1 on: November 23, 2007, 02:49:48 pm »
simon is not saying the truth :p
yellow/red goes to the coolant flange
blue/white goes to the coolant flange
yellow goes to the oil pressure switch above the coolant flange.
what did you do that you needed to take this apart?
Reply #2November 23, 2007, 02:52:19 pm
2mAn
« Reply #2 on: November 23, 2007, 02:52:19 pm »
Quote from: "vanagonturbo"
new headgasket :oops:
Reply #3November 23, 2007, 02:53:32 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #3 on: November 23, 2007, 02:53:32 pm »
again?? how much boost were you running? Dont mess with those cam bearing cap bolts ummkay?
Reply #4November 23, 2007, 03:02:09 pm
2mAn
« Reply #4 on: November 23, 2007, 03:02:09 pm »
heheh
i wont mess with the cam bearing caps without my torque wrench and triple checking those  :lol:
Reply #5November 23, 2007, 03:10:22 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #5 on: November 23, 2007, 03:10:22 pm »
Hmm have you talked to him about this? Remember, one person cannot review another persons work entirely without looking at every single thing the other person did. things like fan wiring are not normally disconnected to replace an engine. What was incorrect about the gauge wiring?
Reply #6November 23, 2007, 04:09:08 pm
2mAn
« Reply #6 on: November 23, 2007, 04:09:08 pm »
anyone wanna buy a  jetta coupe TD?   :cry:
Reply #7November 23, 2007, 04:25:16 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #7 on: November 23, 2007, 04:25:16 pm »
Hmm, well did he acknowledge that you didnt have a functioning temp gauge?
Why would you talk about selling it when you are so close?
Sounds like the smoke is from a timing problem. Is the cooling system overpressurizing? Did you check the head with a straightedge for warpage?
Reply #8November 23, 2007, 04:42:35 pm
2mAn
« Reply #8 on: November 23, 2007, 04:42:35 pm »
i love how you refer'ed to yourself in the 3rd person
 :mrgreen:
me, the coupe and a bunch of coronas will see you tomorrow :wink:
Reply #9November 23, 2007, 08:34:34 pm
the4ork
  • 331
« Reply #9 on: November 23, 2007, 08:34:34 pm »
Quote from: "2mAn"
i do! my gf needs a gas saver :P
Reply #10November 23, 2007, 09:09:55 pm
2mAn
« Reply #10 on: November 23, 2007, 09:09:55 pm »
Quote from: "the4ork"
Quote from: "2mAn"
it was a saracastic remark. ill never figure out how to be sarcastic over the net  :roll:  :o
Reply #11November 23, 2007, 10:18:47 pm
the4ork
  • 331
« Reply #11 on: November 23, 2007, 10:18:47 pm »
you have to add a smiley at the end like this...
anyone want to buy my mk2 20v GTI? 5 bucks!  :lol:
