Author Topic: Intermediate Shaft Bearings/choices...  (Read 2913 times)
November 23, 2007, 07:54:50 am
Wolfsbur
  • 37
« on: November 23, 2007, 07:54:50 am »
Two replacement choices--reamed and non-reamed.
Are the non-reamed up to snuff--anyone use these types?
Thanks
Geoff
VR6 93 Passat
1.8 89 Jetta
1.6 TD 83 Jetta
2.0 95 Golf
Reply #1November 23, 2007, 06:10:42 pm
CoolAirVw
  • 175
« Reply #1 on: November 23, 2007, 06:10:42 pm »
reamed vs non-reamed???  The terminology I use is finish in place or not.
I used ones that do not need to be finished in place and they worked great.
If you use finish in place you'll have to have your machine shop size them after install.  (extra cost)
Before
After
I have only 100 or so miles on the rebuild so only time will tell if they last.  But they definatly are holding the oil pressure.
discussed on this thread  http://www.vwdieselparts.com/forum/viewtopic.php?t=4923&highlight=
85 Jetta Turbo Diesel
75 Porsche 914
93 GMC Truck
99 Caravan <--wifes gotta drive something :)
Reply #2November 24, 2007, 01:00:13 pm
Wolfsbur
  • 37
« Reply #2 on: November 24, 2007, 01:00:13 pm »
Thank you!
I pulled the I. Shafts out on 3 1.6 TD's I have in my shed--each one had flaked apart bearings on the pulley side--one had the trans side completely worn down.
When I went to my local VW parts place to inquire about availability,  they asked 'reamed,  or not'.  The older parts guy there said reamed would allow for any wear/cleanup of the I.S. to be compensated for when the shop machines the 'reamed' bearings to size.
Geoff
VR6 93 Passat
1.8 89 Jetta
1.6 TD 83 Jetta
2.0 95 Golf
Reply #3November 25, 2007, 10:19:40 pm
  • 2932
« Reply #3 on: November 25, 2007, 10:19:40 pm »
I've found clevite to fit best, for non-reamed bearings.
 I tried another non-reamed brand,... might be durabond, it's posted on here somewhere.... they were too loose for my liking.
