Author Topic: pug 306 td injectors in a 1.6 td vw  (Read 2161 times)
November 19, 2007, 12:41:43 pm
snakemaster
  • 405
« on: November 19, 2007, 12:41:43 pm »
pug 306 td injectors in a 1.6 td vw would this give the vw more power . or is there a stock injector out of a nother car that would be beter ie for more power
Reply #1November 19, 2007, 01:06:53 pm
gnavs
  • 340
« Reply #1 on: November 19, 2007, 01:06:53 pm »
not sure about those, but there seems to be mixed feelings about Merc 300TD nozzles.  some say they flow more and make more power, others say the difference is negligible.  I picked up a set of GTD nozzles but havn't installed them yet.  Either way, new nozzles will outperform worn out ones.
Reply #2November 19, 2007, 05:41:13 pm
xud9te
  • 88
« Reply #2 on: November 19, 2007, 05:41:13 pm »
306 / zx dTurbo nozzles and 1.9 gtd nozzles are very similar.  The PSA nozzles are designed for 185 bar opening though so may be a bit tighter in spray pattern.
Go for sprinter or merc 300 ones as suggested, I had both of these and they gave a 300rpm idle rise on the 1.9 pug engine.  Merc ones seem to be a bit better for top end though, they are probably higher overall flow.  merc dnsod265 with 185 opening is the best compromise i have found after using 135bar, 155 bar, sprinter, standard and merc.  i use 50% veg though.
