Author Topic: To soot or not to soot  (Read 3037 times)
November 17, 2007, 11:46:26 am
Riverfurm
  • 122
« on: November 17, 2007, 11:46:26 am »
Got about 1000mile on my 1.6 turbo motor. It has a Giles pump set at .95, 3" SS passenger downpipe, 3" ex. with a flowmaster and runnin 20 psi max on boost.  It's in an 86 Golf two door.
The back of the car gets sooted up after about a week. I played with the max fuel screw. It seem no soot no power. The max EGT I get is about 1150F under an hard pull with 20 psi boost allot of smoke.
Is this about normal? My fuel milages seems good (38-40 MPG). Full boost is about 3800-4500 rpms. I also notice when the engine is hot the turbo woks better.
So can I make this engine not soot up my hatch back, but still keep my new found power?
Thanks for any help.
Riverfurm on the Delware
86 Golf 1.6 Turbo, Giles IP, Pass 3"dp and 3"ex
Fleet of Ford Diesels and Case Equipment
Reply #1November 17, 2007, 11:51:13 am
Black Smokin' Diesel
  • 656
« Reply #1 on: November 17, 2007, 11:51:13 am »
Turn down exhaust tip. I wouldn't reduce power to keep soot off my rear end.
Reply #2November 17, 2007, 11:57:53 am
gnavs
  • 340
« Reply #2 on: November 17, 2007, 11:57:53 am »
x2
the back of my jetta gets sooty, but i have straight exhaust tips.
Reply #3November 17, 2007, 12:24:12 pm
« Reply #3 on: November 17, 2007, 12:24:12 pm »
the turbo likes the hot oil because its thinner.  if you want your turbo to last, don't beat on it when the engine is cold.  i try to stay out of 5 psi range until the engine hits 1/4 on the gauge.
Reply #4November 17, 2007, 10:12:22 pm
TD_Bunny
« Reply #4 on: November 17, 2007, 10:12:22 pm »
hey do you have a IC in your Golf with those EGT?
Reply #5November 18, 2007, 03:59:49 pm
subsonic
  • 1836
« Reply #5 on: November 18, 2007, 03:59:49 pm »
What they said, slight turn down on the tip.  If you are getting the soot you have room(fuel) for more boost.  IC and try and boost a few more pounds.
Reply #6November 19, 2007, 03:19:45 am
stewardc
« Reply #6 on: November 19, 2007, 03:19:45 am »
Get some synthetic oil into that engine once it's properly broken in and the turbo will really love you.
Reply #7December 01, 2007, 06:52:18 am
Riverfurm
  • 122
« Reply #7 on: December 01, 2007, 06:52:18 am »
Quote from: "TD_Bunny"
No intercooler
