General Information
General
how do i wire up my tacho and my battery light always on!!!
Topic: how do i wire up my tacho and my battery light always on!!! (Read 5641 times)
November 08, 2007, 02:03:18 pm
rov716y
November 08, 2007, 02:03:18 pm »
just put a series one dash into my mk1 golf and it has a rev clock which i would like to see work. my alternator has no w terminal so was wondering how i go about wiring it up?
and my battery light is on all the time until i start the engine. even with the keys out of the ignition
November 08, 2007, 02:05:51 pm
November 08, 2007, 02:05:51 pm »
lots of previous discussion on this one... search for W-terminal and away you go. Bottom line... you need a W-terminal somehow.
Batt light on all the time suggests a cluster issue, assuming it didn't do this in advance of the swap /? Not quite sure what you mean by "series one" dash ??
November 08, 2007, 10:58:20 pm
rov716y
November 08, 2007, 10:58:20 pm »
sereis one
sereis 2
November 09, 2007, 01:41:53 am
Ziptar
November 09, 2007, 01:41:53 am »
I see the problem. That dash is totally defective, the cluster is completely on the wrong side. It's where the glove box ought to be and the glove box is where the cluster ought to be.
Must have been made at the height of Oktoberfest and the VAG employee that made that thing must have been really hungover that day.
Get a correct one, and you should be good to go.
November 09, 2007, 09:46:58 am
FineFrank
Dash
November 09, 2007, 09:46:58 am »
maybe it's from a parallel universe.......[/code][/quote]
Frank Longtine
1983 Rabbit Diesel 4 dr/ 1.6NA
1997 Rokon Trailbreaker
1984 Ford F-150/ 300-6
"The welfare of humanity is always the alibi of tyrants" -Albert Camus-
November 11, 2007, 02:20:06 am
rov716y
November 11, 2007, 02:20:06 am »
ok i have now worked out i need a diff alternator or do an operation on mine to get the rev clock to work.
but still cant work out why the battery light is always on?!?
General Information
General
