Author Topic: do the early a3's use cable shift with aaz?  (Read 3805 times)
November 02, 2007, 07:23:53 pm
trent77
  • 217
« on: November 02, 2007, 07:23:53 pm »
Just wondering if the aaz  engines use the cable shift trans or did they continue with the linkage for awhile? or did all a3 use cable shift?
91 (former)eco jetta now aaz (sold to Ben)
05 passat tdi (sold)
77 westfalia
06 GMC Duramax
10 Jetta sportwagen tdi
81 Rabbit pickup (Caddy)
Reply #1November 03, 2007, 12:57:41 pm
g-spec
  • 289
« Reply #1 on: November 03, 2007, 12:57:41 pm »
Mine is a 95 but built in 94...and it uses the linkage!! not cable!! only the vr6 came with a cable in the mk3's iirc!!!
cheers, Michal
Reply #2November 03, 2007, 01:18:42 pm
trent77
  • 217
« Reply #2 on: November 03, 2007, 01:18:42 pm »
sounds good, thank you
77 westfalia
06 GMC Duramax
Reply #3November 03, 2007, 02:28:46 pm
stewardc
« Reply #3 on: November 03, 2007, 02:28:46 pm »
No cable till TDI.
Reply #4November 03, 2007, 08:21:21 pm
windex
  • 13
« Reply #4 on: November 03, 2007, 08:21:21 pm »
96 MKIII golf here, linkage as well...
Reply #5November 04, 2007, 12:27:28 am
« Reply #5 on: November 04, 2007, 12:27:28 am »
i believe all the passat's from 93 up are cable
Reply #6November 04, 2007, 03:20:22 am
Henchman
  • 183
« Reply #6 on: November 04, 2007, 03:20:22 am »
My 93 Passat AAZ is cable.
Reply #7November 04, 2007, 03:23:37 am
MJF
  • 581
« Reply #7 on: November 04, 2007, 03:23:37 am »
All Passats 3/88-96 are cable
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #8November 04, 2007, 03:50:59 am
stewardc
« Reply #8 on: November 04, 2007, 03:50:59 am »
That's a strange statement, because I have a tranny from a 1996 Passat and it's linkage. :?
Reply #9November 04, 2007, 05:30:44 am
andy2
« Reply #9 on: November 04, 2007, 05:30:44 am »
Just to clear things up the passat with AAZ or TDI all had cable shift trans.The diesel MK3 Jetta only got cable shift trans with the TDI 97.5-99.
Reply #10November 04, 2007, 08:50:10 am
Mk2Fanatic
  • 93
« Reply #10 on: November 04, 2007, 08:50:10 am »
Quote from: "stewardc"
did the trans come out of a 2l ABA passat.  I've seen a couple of those with the linkage...
5 VW's: Mojave beige (LE1N) Mk1 rabbit 16V; Mk2 Jetta wolfsburg TDI conversion;Mk2 1.6TD Twin Charged Project; 86Mk2 1.6TD Jetta (daily); 1988 1.6NA Jetta; 1994 Passat 1.9TD donor
Reply #11November 04, 2007, 10:39:34 am
Black Smokin' Diesel
  • 656
« Reply #11 on: November 04, 2007, 10:39:34 am »
MK3 with the 2.0 ABA engine had a cable shift tranny (02a), the early 1.8 8v,  MK3 engines were linkage, IDI diesels were linkage, VR6 were cable so were TDI.
Reply #12November 04, 2007, 10:42:01 am
stewardc
« Reply #12 on: November 04, 2007, 10:42:01 am »
1.9 AAZ engine = linkage
Reply #13November 04, 2007, 11:03:06 am
« Reply #13 on: November 04, 2007, 11:03:06 am »
Unless it's in a 93 and up Passat, in which case it may well have a cable... like my brother's AAZ-equipped 1994 Passat.
