Author Topic: Is it common for hard line fittings to leak after removal?  (Read 5405 times)
March 07, 2005, 07:35:33 pm
evolveVW
  • 4
    • http://www.fastdubs.net
« on: March 07, 2005, 07:35:33 pm »
I took the hard lines off to changes the glow plugs and now that they are back on both leak a little at the injectors, and one is dripping at the pump.  Did they not seat correctly when I tightened the fittings?  Please help as the hell that was my water pump install is over and I just want to drive my car!
1994 Golf GL 1.8T
1981 Rabbit LS Diesel
Reply #1March 08, 2005, 01:07:17 pm
Hammy
  • 169
« Reply #1 on: March 08, 2005, 01:07:17 pm »
It is possible that they did not seat properly. Try loosening off the flare nuts to the leaking lines, and retighten them.
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
'98 GMC 1500 4x4, 5.7L (doing my best to save the oil companies, 85 liters takes me 600 km)
'78 Ford 3000 3cyl, 201 diesel, with loader
Reply #2March 09, 2005, 08:26:08 pm
dieseltech
  • 129
    • http://www.geocities.com/dean16v/Page_One.html
« Reply #2 on: March 09, 2005, 08:26:08 pm »
unloosen the nut, push the steel line in toward the fitting and tighten the nut again. they are somewhat tight toque, snug em up then give a little extra torque. you should be ok unless you cracked a line
86 td jetta power everything dd (update off the road for major resto).  97tdi bare bones, DD
and a private junkyard of various other vw/audi/bmw/peugeot/volvo/toyota diesels!!!
Cummins has the worlds record for being the most efficient engine ever!!!!!
for converting fuel into noise!
Reply #3March 10, 2005, 06:34:39 pm
andy2
« Reply #3 on: March 10, 2005, 06:34:39 pm »
The inj line would need to be loosened off on both ends,If you tightened one end before seating the other end chances are that one or both ends will leak.To get both ends centered properly you just need to tighten each end by hand and wiggle the line when doing so, then you can snug them both
