Author Topic: oil feed and drain ok if not vertical?  (Read 9982 times)
Reply #15October 23, 2007, 09:07:15 pm
jolotter
  • 67
« Reply #15 on: October 23, 2007, 09:07:15 pm »
Wow, Benjamin.  Thanks for that turbo manual!  Now that's bedtime reading.  I also now know why people around here get so excited about VNTs.
Johann
83.5 Vanagon soon to be equipped with
1990 1.6 TD engine
93 Golf 1.9TD and spare engine/tranny
Reply #16January 19, 2008, 09:12:52 am
« Reply #16 on: January 19, 2008, 09:12:52 am »
To back up the above post, this is from a Garrett tech support manager talking about a VNT 25.
This turbo needs .3 gpm of oil @ 30 psi. minimum at full power. Any oil that you can use in the engine will work for the turbo. The oil drain uses one bolt and seals with an O ring. A flat flange with a gasket will also work. A .5 inch minimum inside diameter oil drain is recommended and must be within 30 degrees of vertical with no "sink traps" that will allow oil to puddle.
Taken from here.
