General Information
Troubleshooting
am i in trouble?
Topic: am i in trouble? (Read 5529 times)
October 17, 2007, 05:06:39 pm
2mAn
am i in trouble?
October 17, 2007, 05:06:39 pm »
im helping a friend change a headgasket and we got 9 out of the 10 headbolts loose and out, no problem. one broke loose farily easily like the rest, but has been getting harder and harder to loosen. im afraid something is about to break so we've stopped where we are at. am i paranoid for no reason or am i about to break something?
thoughts?
October 17, 2007, 05:53:19 pm
2mAn
am i in trouble?
October 17, 2007, 05:53:19 pm »
nevermind we got it off!
October 18, 2007, 04:18:59 am
somolovitch3
am i in trouble?
October 18, 2007, 04:18:59 am »
You are going to chase the threads in all the bolt holes, yes ?
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
October 18, 2007, 05:06:44 am
am i in trouble?
October 18, 2007, 05:06:44 am »
if not you'll be doing another headgasket in the not so distant future because you won't torque it properly
October 20, 2007, 04:44:30 pm
2mAn
am i in trouble?
October 20, 2007, 04:44:30 pm »
yea ill mkae sure that happens, but since we're on the subjuect. wheres can i get a new HG and head bolts for cheap?
October 20, 2007, 07:15:28 pm
am i in trouble?
October 20, 2007, 07:15:28 pm »
hmmm makes me wonder why it was so hard to remove. the head bolts on my TDI were easy as pie to remove with a nice long bar. did you remove them in sequence? maybe you should check the head for warpage.
is it for a 1.6? you could try a 1.9 hg like the rest of us :lol:
October 20, 2007, 08:58:48 pm
2mAn
am i in trouble?
October 20, 2007, 08:58:48 pm »
yup removed them in sequence. i probably should check for warpage, but not really sure what i should be measuring...
any ideas on the HG & head bolts? im not too fond of having to plug a whole in the gasket unless someone has a fool proof way of running the 1.9
October 20, 2007, 10:18:43 pm
am i in trouble?
October 20, 2007, 10:18:43 pm »
ah yes... with solid lifter your best bet is to stick with stock gasket unless you want to be brave and try something new.
General Information
Troubleshooting
am i in trouble?
