Author Topic: 1995 dt 1.9l main and con rod torques  (Read 4939 times)
October 15, 2007, 05:00:10 pm
Al h
« on: October 15, 2007, 05:00:10 pm »
Hi I can't seem to find any torque specs for the stretch bolts for the con rods or main bearing caps. Can anyone send me a link to the proper spec sheets.Thanks Al
Reply #1October 16, 2007, 09:30:32 pm
starrd
  • 128
Torques
« Reply #1 on: October 16, 2007, 09:30:32 pm »
..........................................................................Ft. Lbs. (N.m)
Connecting Rod Cap Bolt ............................ (1)(2)  22      (30)
Crankshaft Bearing Cap Bolt ....................... (1)(2)  48      (65)
(1) - Tighten bolt to specification plus additional 90 degrees.
(2) - Use NEW bolts.
Black 1996 Passat TDI Malone tune, K03/04 Hybrid, Keyless, VR6 Clutch & PP357's
White 1993 Passat TD - GTD nozzles, Keyless - Giles pump, K14, Intercooler, 228mm VR6 clutch & PP, CTN Trans etc
Red 1990 Corrado - custom chip by
