Author Topic: HELP !! AAZ WONT REV ?!?!?!?  (Read 2516 times)
October 15, 2007, 09:46:36 am
ELVIS
  • 51
« on: October 15, 2007, 09:46:36 am »
just fitted an AAZ in my T3/T25/Vanagon/whateveryacallit.
    started it today and it wont rev , open throttle fully and i just get a 'fast tickover' sorta response! :cry:  the engine was sweet when taken out and my van ran ok(ish) - the SB engine died but fuel system was ok .
   now the engine is in , nothing ! have done nothing and changed nothing to affect it. even though it ran ok i have taken off LDA cleaned it spotless , replaced LDA line.
   i am guessing fuel - only thing i can think of is maybe the fuel filter. i have the type where the fuel enters the side of the filter head and it exits via a banjo fitting , do you guys normally go for the different / later filter type ( has two 90' bent tubes coming from top )
   help ! :D
Reply #1October 15, 2007, 09:53:19 am
« Reply #1 on: October 15, 2007, 09:53:19 am »
A fuel restriction is also what I was thinking. Do you have any smoke?
Reply #2October 15, 2007, 09:58:33 am
ELVIS
  • 51
« Reply #2 on: October 15, 2007, 09:58:33 am »
nope! cant get it to run fast enuff  :lol:  runs at tickover with/without cold start , on full throttle it increases maybe 200 rpm ? when you swap from a 1.6td to an AAZ do most people swap the filters aswell ? is it a 'common' occurance ? when i open throttle fully and look at the clear inlet the fuel continues to flow at a constant speed - before you could see it spped/slow as demanded. nothing has been changed on pump. havnt played/tinkered/fiddled with it- honest!!! cheers    elvis
Reply #3October 15, 2007, 10:39:58 am
« Reply #3 on: October 15, 2007, 10:39:58 am »
I think the whole thing is toast, and that you should just give it to me.  :wink:
Reply #4October 15, 2007, 11:37:04 am
ELVIS
  • 51
« Reply #4 on: October 15, 2007, 11:37:04 am »
:lol:   i am a fool! throttle arm in wrong place  :roll:  runs sweet as now! Jimfoo , seen what they go for on US ebay  :shock:  mine was from aan accident damaged passat (quantum?) 100k , spotless - no oil or water marks on it , full service history   £150 - about $300 USD  :shock:  :lol:
