Author Topic: aaz into a mk1 cabrio build  (Read 74057 times)
Reply #150March 31, 2010, 02:35:40 pm
Re: aaz into a mk1 cabrio build
« Reply #150 on: March 31, 2010, 02:35:40 pm »
On this cam is there no time when the intake and exhaust are open at the same time? I figure that would be best for a turbo app. Also, I knew it was a custom grind and I am going to be in need of a Mech one though...but like I said I just need to get it done.
Nope, there's no room to have any overlap - the piston is essentially flat against the head at TDC, so you can't possibly have the intake and exhaust valves open at the same time like you would on a gasser.
Not overlap in the piston and cam, but the intake and exhaust lobes. Burn has a cam spec table and it shows overlap with every cam he has done stock. For highest boost without loss you would want close to zero if I am recalling correctly.
Reply #151April 01, 2010, 12:08:19 am
  • 3468
    • McScrubbins Body Wash
« Reply #151 on: April 01, 2010, 12:08:19 am »
If you had valve overlap you would bleed boost on the exhaust stroke. You don't really have to recall anything. just think about it - 4-stroke engine.
intake, compression, power, exhaust...
on intake stroke if you had some exhaust valve over lap it might rid the cylinder a little better of the exhaust gases with that rush of air from the turbo - but there is a fine line here between wasting boost and getting lots of clean 02 into the cylinder...
on compression ... well that doesn't need ANY thought hahahahh
power, same as compression...
exhaust, having a marginal amount [how much i have NO idea] of valve over lap here would be slightly beneficial but again its the same issue as the intake stroke - lost/wasted boost pressure unless you had such a big turbo and were fueling it enough such that you could "afford" to spend boost on such things... after all it would just go through the turbine on the other side anyways.
I know you all were already thinking what i just said, i just like to illustrate it - i find it easier to visualize.
In my completely inexperienced opinion; a tiny tiny amount of valve over lap might be advantageous to ensure the exhaust is totally getting out of there - just like how having a couple degrees of over lap helps a big/small block make bigger power.
« Last Edit: April 01, 2010, 12:14:50 am by Smokey Eddy »
Reply #152April 01, 2010, 12:12:45 am
truckinwagen
  • 1895
« Reply #152 on: April 01, 2010, 12:12:45 am »
I have a hard time believing that the diesel cam has much(if any ) overlap.
the piston to valve relationship would make it really difficult, and most of the stock gasser cams have negative overlap(that is rotation where both valves are closed)
what I would love to see is a diesel cam with stock duration and timing, but more lift.
83 Opel Kadett Diesel
Reply #153April 01, 2010, 12:17:12 am
  • 3468
« Reply #153 on: April 01, 2010, 12:17:12 am »
I too would love to see Maximum lift on a cam. To the point where the valves are chasing the piston as it goes down. Also add 2 more valves per cylinder...
I agree that a stock cam would have zero over lap.
Reply #154April 01, 2010, 06:16:00 am
« Reply #154 on: April 01, 2010, 06:16:00 am »
This is from tylers post and if I read this correctly there is the overlap of intake and exhaust being open at the same time. On small and big blocks that get turbos the usually get a custom grind cam that has the intake closed and right after then the exhaust opens. That way the intake charge doesn't leave out the exhaust. For naturally aspirated the cams are built opposite and you can run tuned headers to actually pull more into the combustion chamber.
Disclaimer: I am not a professional engine builder, but I have stayed at a motel 8. This is just the way my head machinist and I have talked about it and he even said under 20lbs boost it really doesn't matter.
Reply #155April 01, 2010, 09:44:41 am
« Reply #155 on: April 01, 2010, 09:44:41 am »
Yes there certainly is overlap. For the record, those are cam degrees,not crank.
Reply #156June 26, 2010, 10:14:29 pm
Darkness_is_spreading
  • 288
« Reply #156 on: June 26, 2010, 10:14:29 pm »
Hey when you installed this motor into the Cabrio, did you have to change the passenger side engine mount...  (Ie removing the IP and replacing the brackets to to match up)?
To me it looks like this must be done in order to support the motor properly in the first gen frame....
92 Jetta 1.6 T (Sleepin)
Reply #157June 27, 2010, 05:37:06 pm
« Reply #157 on: June 27, 2010, 05:37:06 pm »
Yes the pass motor mount needs to be replaced with the MK1 diesel version.
Reply #158June 28, 2010, 09:55:49 am
« Reply #158 on: June 28, 2010, 09:55:49 am »
I did a leakdown test on my rabbit and found that at TDC on the exhaust stroke it wouldn't hold any pressure, when I turned it a little either way it sealed up. Definitely overlap.
Reply #159February 21, 2011, 05:34:28 am
ktownboostn
  • 31
« Reply #159 on: February 21, 2011, 05:34:28 am »
Damn ! This car has come along way since i saw it at Jitterbug 09 !
Really interested in the info on the cam. IS it still possible to have them re-ground ? has the guy left the country ? Anyone else know the details ?
2001 VW Jetta 24v VR6 - Rally Car
1990 VW Jetta AAZ/MF - Daily coal roller
1986 VW Cabriolet 12v VR6 - Project car
Reply #160February 21, 2011, 06:51:41 am
stewardc
« Reply #160 on: February 21, 2011, 06:51:41 am »
Isn't Giles (erformance Diesel Injection) the dealer for them now ?
Reply #161February 21, 2011, 06:26:14 pm
Giles@PerformanceDiesel
  • 221
    • http://www.performancediesel.ca
« Reply #161 on: February 21, 2011, 06:26:14 pm »
yes Dr D. has passed on the duty to me now.
i have two freshed gound cams in stock if anyone wants one.
Giles
Reply #162February 21, 2011, 06:27:03 pm
« Reply #162 on: February 21, 2011, 06:27:03 pm »
Amazazazing. :)
this looks great, how is it now!!
Reply #163March 07, 2011, 12:25:38 am
Digital K
  • 58
« Reply #163 on: March 07, 2011, 12:25:38 am »
great thread :)
