aaz into a mk1 cabrio build
Pages:
6
7
8
9
10
11
Topic: aaz into a mk1 cabrio build (Read 74024 times)
Reply #120
May 30, 2009, 02:30:46 pm
giulianot
Re: aaz into a mk1 cabrio build
Reply #120 on:
May 30, 2009, 02:30:46 pm »
Today was a great day! I made it down to diesel doctors dyno day and put my cabby with its new setup on the rollers. I was the only IDI to dyno today, alot of nice tdi's and even a 09 2.0 tdi ! so here is a video of one run and my dyno sheet.
I put down 133 hp and over 200 flbs of torque
Im pretty happy with that for now .
1990 cabriolet 1.9 aaz, kkk 24/26, Giles pump, big 2.5" intercooler, 3 " P.P. downpipe
Reply #121
May 30, 2009, 04:11:39 pm
hamradio
Reply #121 on:
May 30, 2009, 04:11:39 pm »
Very impressive! I'm envious.
That thing must pull like crazy..bust up any 020's yet?
Reply #122
March 16, 2010, 02:02:36 pm
giulianot
Reply #122 on:
March 16, 2010, 02:02:36 pm »
time for some updates. Last fall before putting the car away for the season I did a compression test and leakdown test. I found that cylinder 1&2 had low compression and were leaking at the intake valves, so i tore the head off again and sent it out for new valves and seals.
and the head comes off again
I start to assemble refurbished head
I installed all new valve lifters , I used lucas as assemble lube
A shot of the bottom of the cam and the head with the new valves and new precups pressed in
a look at how bad my old precups were burned out from over fueling and high egts
Next I installed the cam and torqued down the caps
glowplugs were next
then injector heat shields and injectors torqued to 51 ft/lbs
Exhaust manifold studs installed
Intake manifold torqued to 15 ft/lbs
Exhaust manifold spacers installed
Finally the exhaust manifold gets torqued to 15 ftlbs
the kkk 24/26 gets bolted to the exhaust manifold and torqued to 50 ft/lbs
Now the head the ready for install so I cleaned the block and put in a new 2 hole head gasket and placed the head on the block. I reinstalled the arp head studs and applied the arp approved lube and torqued the head to 75 ft/lbs.
I connected all the hoses and put some coolant in it started write up!
Reply #123
March 16, 2010, 08:02:43 pm
Reply #123 on:
March 16, 2010, 08:02:43 pm »
Looking good buddy. Hopefully we get some more go out of it on Friday
Reply #124
March 16, 2010, 11:28:37 pm
Reply #124 on:
March 16, 2010, 11:28:37 pm »
I bet a better intake manifold would get you more power/lower EGT's.
Reply #125
March 17, 2010, 05:49:40 am
NintendoKD
dnahtasinoivilboeraweb
Reply #125 on:
March 17, 2010, 05:49:40 am »
That is the PD mani isn't it, wasn't aware that there was one better than that. Nice build.
Reply #126
March 17, 2010, 06:05:30 am
Reply #126 on:
March 17, 2010, 06:05:30 am »
No it is the regular one with no blow off valve.
PD is better.
Performance had one even better.
I got the "best"...I just need to fit it.
Round 2
Reply #127
March 17, 2010, 12:06:05 pm
Reply #127 on:
March 17, 2010, 12:06:05 pm »
Where'd you find the new precups?
Reply #128
March 17, 2010, 07:30:14 pm
NintendoKD
Reply #128 on:
March 17, 2010, 07:30:14 pm »
:oYEAH! what he said!!! where did you get thems cups???
Reply #129
March 18, 2010, 08:03:01 am
giulianot
Reply #129 on:
March 18, 2010, 08:03:01 am »
I really dont know were my head rebuilder got the new precups from, maybe a dealer item only
Reply #130
March 18, 2010, 07:28:21 pm
NintendoKD
Reply #130 on:
March 18, 2010, 07:28:21 pm »
just who is your rebuilder, or will you tell?
Reply #131
March 19, 2010, 01:55:23 pm
giulianot
Reply #131 on:
March 19, 2010, 01:55:23 pm »
His name is Jim . He was recommended by a friend of mine, and I was happy with his work. he is located in hamilton, ontario, canada and his phone number is (905) 544-8514
Reply #132
March 21, 2010, 09:09:44 am
Dr. Diesel
Authorized Vendor
Reply #132 on:
March 21, 2010, 09:09:44 am »
I just posted a vid of this car in the General section.
Reply #133
March 29, 2010, 02:54:06 pm
giulianot
Reply #133 on:
March 29, 2010, 02:54:06 pm »
I dynoed the cabby on sunday and here are the results
with a dr. diesel high lift cam and a giles pump and k26@24psi egts 1600-1800
Reply #134
March 29, 2010, 03:20:50 pm
Dr. Diesel
Authorized Vendor
Reply #134 on:
March 29, 2010, 03:20:50 pm »
Your car did really well, G! Far more entertaining to watch than any other vehicle that rode the roller.
Copies of this camshaft will be available soon.
And, here's a quick vid of Giuliano's cabby on the dyno.
http://smg.photobucket.com/albums/v225/vwpics/?action=view¤t=MOV00274.flv
Last Edit: March 29, 2010, 03:46:14 pm by Dr. Diesel
Pages:
6
7
8
9
10
11
