Author Topic: Yesterday my TDI hit the rollers and........................  (Read 6252 times)
September 27, 2007, 06:30:28 am
A2TD
« on: September 27, 2007, 06:30:28 am »
No chips and dip.........................
Reply #1September 28, 2007, 07:19:33 am
OM617
« Reply #1 on: September 28, 2007, 07:19:33 am »
Its difficult to see the numbers because of the light ink, what are they?
Reply #2September 28, 2007, 09:03:58 am
« Reply #2 on: September 28, 2007, 09:03:58 am »
277 ft/lbs torque max and almost 184 hp max.
pretty impressive if there is no chipping... but how would you attain that without chipping??? must be bigger nozzles for sure..
Reply #3September 28, 2007, 10:05:18 am
A2TD
« Reply #3 on: September 28, 2007, 10:05:18 am »
184whp 278lbs, on the stock chips, all the timing and fuel was done with a hand full of resistors.................
I have a video I will post up shortly..
Reply #4September 28, 2007, 10:09:10 am
zaprzal
  • 160
    • turbodiesel.pl
« Reply #4 on: September 28, 2007, 10:09:10 am »
what is your setup?
1.6td 170hp 290nm powered by Holset - sold
golf mk2 1.9tdi PD 193hp/400nm ;)
Reply #5September 28, 2007, 11:13:45 am
« Reply #5 on: September 28, 2007, 11:13:45 am »
with a hand full of resistors?  :lol: pretty neat! sounds like a hillfolk mod...
Reply #6October 04, 2007, 10:32:05 am
Holeshot
  • 33
« Reply #6 on: October 04, 2007, 10:32:05 am »
Please do detail the values and placement of said resistors.  :twisted:
I'm running a 670-Ohm resistor (switched) between the #2 and #3 wires of the IP harness - aka: "Evry" mod.
I also have a resistor on the fuel temp wire, but that didn't seem to do much of anything.
Thanks,
Matt
'94 Dodge Ram 2500 4x4 - 12-valve Cummins, NV5600 6spd, SBC Con FE clutch, EDM injectors, etc. ~400rwhp, Isspro EGT/100psi boost gauges
'98 VW NB TDI - not stock by any means, but still pretty tame.  TDI-M candidate :cool:
'00 VW Jetta TDI - wife's 300,000+mi daily driver
Reply #7October 18, 2007, 09:49:07 am
Holeshot
  • 33
« Reply #7 on: October 18, 2007, 09:49:07 am »
Quote from: "A2TD"
How 'bout that video and some more details on the resistors...  8)
Thanks,
Matt
Reply #8October 29, 2007, 09:19:38 am
A2TD
« Reply #8 on: October 29, 2007, 09:19:38 am »
Quote from: "Holeshot"
Quote from: "A2TD"
Thanks,
Matt
Workin on getting the video working, its on an olderskool camera so transfering it over to the comp isn't easy.
Reply #9October 29, 2007, 09:16:30 pm
« Reply #9 on: October 29, 2007, 09:16:30 pm »
you've essentially doubled the HP and more than doubled the torque of the stock engine... WITH RESISTORS!!!
i can't wait to see a video of this!  8)
Reply #10November 08, 2007, 10:57:39 am
Holeshot
  • 33
« Reply #10 on: November 08, 2007, 10:57:39 am »
Still waiting...  :)
In the meantime while you're getting the video prepped - hows about posting information on the placement and values of them there resistors?   8)
Beers,
Matt
