Author Topic: rabbit TDI build  (Read 30672 times)
Reply #45October 28, 2007, 07:20:51 pm
RabbitGTDguy
  • 1274
rabbit TDI build
« Reply #45 on: October 28, 2007, 07:20:51 pm »
Looking good Justin! This particular car is going to have to be moved to the IDI forums as its looking like a very nice build on it alone.
Then...not to mention the TDI that'll eventually come here!
Joe
1972 VW Westfalia
Reply #46October 29, 2007, 07:39:40 am
fuslit
  • 118
rabbit TDI build
« Reply #46 on: October 29, 2007, 07:39:40 am »
Def looking good, glad to hear you got it running under it's own power :)
my vr6 project should be started (and hopefully finished) this weekend than it's onto the body work on the caddy and rabbit.
-Todd
'81 rabbit 4dr 1.6TD [project]
'98 jetta tdi [daily]
Reply #47November 01, 2007, 06:33:13 am
Greasecar
  • 126
    • http://www.greasecar.com
rabbit TDI build
« Reply #47 on: November 01, 2007, 06:33:13 am »
The car is officially registered and insured now.  I've been driving it for the last few days and figuring out what needs to be dialed in.  The first thing was the alignment which was toed way out explaining the funky touque steer feeling I was getting.  I also need to straighten out  the exhaust which buzzes like crazy at idle.
The most boost I have gotten out of the car was 20PSI on the highway.  I am still running the 130bar injectors and it feels like I am hitting a ceiling.  The pump has been modified with the common LDA, governor and timing mods and the fuel screw turned up but I am not getting much smoke to speak of, starts right up and gives some pretty serious performance.
I'm planning on runnning this way for the next couple of weeks to get a baseline on performance and economy, then bumping up to stock 155s then later to the GTD nozzles I got.
I do feel like I may be losing a bit of boost response due to the large IC pipes that I got.  Jay is going to be using 2.25" which sound a bit more suitable.
Here are a couple of video links to check out, hope they work. These were shot in the driveway at the shop so we weren't able to really open her up.
http://s225.photobucket.com/albums/dd32/Greasecar/?action=view&current=RabbitBurnouts001.flv
http://s225.photobucket.com/albums/dd32/Greasecar/?action=view&current=RabbitBurnouts004.flv
I'm driving to Boston on Friday, hopefully I can take the Rabbit if the other half doesn't insist on the Passat.
www.greasecar.com
79 Mini diesel (1.5 Peugeot)
82 rabbit TD (given to Junkcollector Jay)
84 rabbit TD (intercooled w/ VNT)
82 rabbit PD (undergoing swap)
01 Golf TDI (burned to the ground)
02 Golf TDI (355,000 miles and counting)
04 Passat TDI Wagon (Grocery getter)
Reply #48November 01, 2007, 09:51:50 am
rabbit TDI build
« Reply #48 on: November 01, 2007, 09:51:50 am »
Quote from: Greasecar
 :shock:  you mean there's more power? looks really fast!  try tweaking the LDA.  some people grind a more aggressive taper into the pin.  :wink: that way you're getting tons of fuel on boost!
Reply #49November 01, 2007, 10:56:41 am
JunkcollectorJ
  • 45
rabbit TDI build
« Reply #49 on: November 01, 2007, 10:56:41 am »
Awesome!  That thing seems to be running great!  I'm definitely impressed with the power.  I can't wait to bring my car down and take the rabbits for a cruise.
Yes, I'm going to be running a very similar intercooler pipe kit, although mine is 2"...just got it today (so I'll be replacing my exhaust pipe set up asap).  I have a different intercooler though, a spearco I believe, but it's really similar in size.
'82 Rabbit with 1Z TDI swap
Reply #50December 07, 2007, 12:40:39 pm
Greasecar
  • 126
rabbit TDI build
« Reply #50 on: December 07, 2007, 12:40:39 pm »
Just figured I'd give a little update.  I haven't had time to dig into any major projects with the car but was able to do a few cosmetics and some winterizing.
I scored these cool NOS mudflaps to keep the slush at a minimum
Also added this nice Italian steering wheel
and found out where some of my power issues were coming from
and here is another burnout clip for those like that kind of thing.
http://s225.photobucket.com/albums/dd32/Greasecar/?action=view&current=MVI_0024.flv
The major project I have in the works ight now is a mechanical actuator for the VNT since I currently have the vanes wired about in the middle and am loosing out on the bottom end.  There have been a lot of topics covering this and I only hope I can put together a setup half as slick as the one TinTin made.
www.greasecar.com
Reply #51December 10, 2007, 06:43:41 pm
RabbitGTDguy
  • 1274
rabbit TDI build
« Reply #51 on: December 10, 2007, 06:43:41 pm »
Justin, that oil filter doesn't look like fun!
1972 VW Westfalia
Reply #52December 11, 2007, 12:21:22 pm
Greasecar
  • 126
rabbit TDI build
« Reply #52 on: December 11, 2007, 12:21:22 pm »
Even worse, that's the fuel filter!
www.greasecar.com
Reply #53December 11, 2007, 12:52:11 pm
rabbit TDI build
« Reply #53 on: December 11, 2007, 12:52:11 pm »
thats a pretty disgusting fuel filter... fram makes fuel filters or is that an oil filter? looks like an oil filter.
Reply #54December 11, 2007, 01:33:05 pm
blkboostedtruck
  • 1535
rabbit TDI build
« Reply #54 on: December 11, 2007, 01:33:05 pm »
Quote from: "jtanguay"
 I see in the pic. it says secondary fuel filter on it! so it's a fuel filter!
 looks just like an oil filter don't it?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #55December 11, 2007, 02:19:21 pm
Slave2School
  • 531
rabbit TDI build
« Reply #55 on: December 11, 2007, 02:19:21 pm »
I love the Steering wheel.  All you need is anice chrome downturn for the cherry bomb :)  I love the sound of a cherry bomb on a diesel.
2002 ford focme wagon
Reply #56December 11, 2007, 06:15:57 pm
RabbitGTDguy
  • 1274
rabbit TDI build
« Reply #56 on: December 11, 2007, 06:15:57 pm »
guess i wasn't looking too well...still NaSTy!!!
Joe
1972 VW Westfalia
Reply #57December 13, 2007, 05:40:24 am
JunkcollectorJ
  • 45
rabbit TDI build
« Reply #57 on: December 13, 2007, 05:40:24 am »
Quote from: "Greasecar"
power issues??  I've seen the burn out videos, what power issues are you talking about   heheh  ;)
Nice mud flaps, I love the green stripe.
J
