Author Topic: what engine is this starter for?  (Read 6209 times)
September 19, 2007, 05:02:47 pm
insdtanoodles
  • 148
« on: September 19, 2007, 05:02:47 pm »
I bought a starter from autopartsonlinecanada and they sent the wrong one, its been almost 2 months and calling and other BS and still no go with my refund. If it can work on my car I will just keep it or just sell it to someone. The starter on my car has a shaft sticking out of the starter gear and on this one there is no shaft. Pictures work better so here is one I took.
thanks guys
1996 vw jetta AAZ
Reply #1September 19, 2007, 05:59:45 pm
« Reply #1 on: September 19, 2007, 05:59:45 pm »
I see part of a VW part number under the Bosch sticker in the picture (020 911 024 A perhaps ??)... that might help us track it down.
Off the top of my head I vaguely remember that:
 * starters for automatic trannys generally don't have the bushing inside the tranny and so don't have the extended shaft
* there are shaftless versions of the starter for the manual tranny starter (so called "improved design"... you've done a test fit ??  What doesn't fit ??
The part number will be the clincher if you can read it...
Reply #2September 19, 2007, 07:20:31 pm
insdtanoodles
  • 148
« Reply #2 on: September 19, 2007, 07:20:31 pm »
part number is 020 911 024 A and I have looked it up in ETKA and it doesnt say anything other than starter and 1.8kW. I havent done a test fit cause I havent had to take the starter out, if anyone actually knows if it fits I might just keep it as a backup, my old starter gave me problems last winter.
1996 vw jetta AAZ
Reply #3September 20, 2007, 07:17:30 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #3 on: September 20, 2007, 07:17:30 am »
According to evwparts.com, the Bosch SR34X number fits:
Fits Passat 2.8 liter VR6 automatic
Corrado 1992-1994, 2.8L VR6 with Automatic Trans.
Eurovan 1993-1995, 2.5L with Automatic Trans.
Golf 1985-1986, Engine: ME, 1.6L Diesel, 5 Speed Manual Trans.
Golf GL 1987-1988, Engine: ME, 1.6L Diesel, 5-Speed Manual Trans.
Jetta 1984-1989, 1.6L Diesel, 5-Speed Manual Trans.
Jetta GL 1985-1992, 1.6L Diesel, 5-Speed Manual Trans.
Jetta GLX VR6 1994-1995, with Automatic Trans.
Passat GL 1996, Engine: 1Z, 1.9L Diesel Turbo, with Automatic Trans.
Passat GLS Sedan & Wagon 1992-1993, 2.8L VR6 with Automatic Trans.
Passat GLX Sedan & Wagon 1992-1996, 2.8L VR6 with Automatic Trans.
Rabbit 1984, Engine: JK, 1.6L Diesel
According to partsquick.com, the VW number 020 911 024 A actually should be a Bosch SR0407X starter.
Applications:
VW
98-04 Beetle*
99-04 Golf TDI*
04-05 Jetta GL*
97-03 Jetta GL TDI*
02-04 Jetta GL Wagon*
04-05 Jetta GLS*
99-03 Jetta GLS TDI*
99-99 Jetta GLS VR6*
02-05 Jetta GLS Wagon*
96-99 Jetta GLX VR6*
97-97 Passat GL*
97-97 Passat GLX*
Calvin
91 VW Golf 1.6NA 5spd
Reply #4September 20, 2007, 08:34:43 am
houseofdiesel
  • 210
« Reply #4 on: September 20, 2007, 08:34:43 am »
Did you actually try to install it? I think you will be surprised to find it fits and it is a much better starter then the older ones with the long nose that requires a bushing...
Bosch updated some of the older starters to this design, no more brass bushing inside the bell required to support it, much stronger sounding motor and better cranking it is basically a tdi starter motor designed to fit the older motors
Greg
Reply #5September 20, 2007, 06:51:12 pm
insdtanoodles
  • 148
« Reply #5 on: September 20, 2007, 06:51:12 pm »
Quote from: "clbanman"
Applications:
VW
98-04 Beetle*
99-04 Golf TDI*
04-05 Jetta GL*
97-03 Jetta GL TDI*
04-05 Jetta GLS*
97-97 Passat GL*
97-97 Passat GLX*
my car isnt in that list but I guess the only way to know for sure is to install it and try, thanks.
1996 vw jetta AAZ
Reply #6September 21, 2007, 06:42:30 pm
akrallysport
« Reply #6 on: September 21, 2007, 06:42:30 pm »
Looks identical to the one I installed last year on my AAZ... I don't see a problem.
Reply #7September 22, 2007, 02:48:27 pm
insdtanoodles
  • 148
« Reply #7 on: September 22, 2007, 02:48:27 pm »
Quote from: "akrallysport"
yeah, I just installed it on my car and it is working fine. Now I gotta a backup come winter time if my other one fails
1996 vw jetta AAZ
