Author Topic: Heat not hot enough on '92 Jetta Eco...  (Read 4457 times)
September 17, 2007, 09:16:03 am
larry104
  • 200
« on: September 17, 2007, 09:16:03 am »
Anybody have the heat not work well on an A2 Jetta? What'd you do to fix it? The coolant is full, the thermostat is good, and the engine reaches proper operating temperature (between 1/2 and just under 3/4 on the gauge). The cooling fan kicks in at just below 3/4 and runs until it reaches 1/2. I'm thinking it's the blend door. The cooling system is clean, so I don't think it's a plugged heater core. Anybody?
Reply #1September 17, 2007, 09:24:13 am
« Reply #1 on: September 17, 2007, 09:24:13 am »
sounds like the blend door.  there should be a valve to send the hot coolant through the heater core.  check the temp of the coolant lines going to the heater core when the motor reaches operating temp.
could be a clogged heater core though...
Reply #2September 17, 2007, 09:29:29 am
« Reply #2 on: September 17, 2007, 09:29:29 am »
MK2s don't have valves to allow coolant through the heatercore, it is always flowing through it. Only mk1s have the valve. It might be the foam inside the heater box that is used to control the hot/cold. One sure fire way to check is when the engine is getting warm (but not hot) grab each line going to the heatercore, they should both be the same temperature. If you try the check when the engine is fully hot they will both be the same temperature because of heat transfer through the coolant.
Reply #3September 17, 2007, 09:36:12 am
MikkiJayne
  • 235
« Reply #3 on: September 17, 2007, 09:36:12 am »
Have you got the heater core bypass valve installed? One of the valves on my Corrado failed and stopped most of the flow through the heater core. I took it out and it works again - just got to watch the core doesn't pop!
Mikki x
Reply #4September 17, 2007, 12:34:00 pm
« Reply #4 on: September 17, 2007, 12:34:00 pm »
Quote from: "burn_your_money"
hmmm i thought mk2's had it... guess not
Reply #5September 17, 2007, 05:46:30 pm
bevboyy
  • 200
« Reply #5 on: September 17, 2007, 05:46:30 pm »
Get your cooling system flushed.
1987 Jetta Mk2 - daily driver, MZ 1.8 goodness. TJ auto trans..
Gone but not forgotten:
1985 Mercedes 300d Turbo
1987 Olds Delta 88 Royal Brougham
1992 Mercedes 190e 2.3
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1979 Mercedes 300D (non turbo)
1977 BMW
Reply #6September 23, 2007, 05:26:39 pm
larry104
  • 200
« Reply #6 on: September 23, 2007, 05:26:39 pm »
Well, there was nothing wrong with the heater, except bad design. The heater core flow is always on, as was pointed out above. Inside the heater box are vacuum-actuated doors to control defrost, floor, and vent. A cable operates the blend door, which diverts outside air to the heater core.
The blend door is perforated with several large holes. These holes don't let enough outside air pass over the heater core when the temp control is slid to "hot."  I cut a sheet of thin aluminum and drilled it and the blend door for sheet metal screws (no fun). I covered all but the four small holes in the blend door top and bottom. I put it back together and, wow, HEAT!  The A/C still works fine. No problems.
To get to the door, you must remove the center console, knee bar, the center vent (2 lock tabs on the lower surface, 2 phillips head screws in the top surface), and the manifold that connects to the center and defrost vents (What a PITA).
While apart, I replaced the old foam gasket on the manifold with 3/8 in. wide self-adhesive weather stripping. I used the same stuff to fix the leaky center vent shut offs. No more whistling, and they actually work.
Ready for winter. :D
Reply #7October 15, 2007, 01:22:55 pm
« Reply #7 on: October 15, 2007, 01:22:55 pm »
Hey I got a question. I think I figured out that my '82 rabbit has an old style heater core housing from a 1977-80 in it. Actually I just remembered mine has the vents in the dash below the radio but there is no air duct going to it, there isn't even an opening in the heater box to hook a duct. The only heater options are floor and defrost but the inside of the car never gets comfortable (unless your wearing carharts, fur hat and gloves :( ). I went through last winter with a pitiful heater and I'm not looking forword to doing it again. :roll: thanks guys
