VWDiesel Blog
Facebook Group
VWD on Twitter
For Sale/Looking For
Parts for Sale/Wanted
1.6 TD pump $70
Topic: 1.6 TD pump $70 (Read 3561 times)
September 13, 2007, 02:50:26 pm
1.6 TD pump $70
September 13, 2007, 02:50:26 pm »
Not mine but someone may want to jump on this
http://forums.vwvortex.com/zerothread?id=3439966
actually, looking at the pictures, is that the alt compensating thing?
September 13, 2007, 07:50:25 pm
blkboostedtruck
1.6 TD pump $70
September 13, 2007, 07:50:25 pm »
Tyler,
on that pump in the pic. what does that adjustment screw do on the back of the pump where the retard cable hooks too? on mine i'm leaking fuel in that area! is that a simple "O" ring fix? or is that more complicated? should i send it out ? i've done one on the front and that was easy? but not sure about the back side? I noticed the MK1 pumps don't have that adjustment thing! is there a preference between the MK1 and MK2 pumps ? that you are aware of?
thanks Duane
injector rebuilds call 414-840-1395 for faster service not on line much!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
3 jettas '82' '04 '14TDI
September 14, 2007, 01:32:32 am
1.6 TD pump $70
September 14, 2007, 01:32:32 am »
I believe that is the idle increase. I don't know how hard that seal is to replace.
You can try filling your pump with ATF and letting it sit for a day or two. I just did this on my grama's car and it fixed the leak. I don't know how long it will last but at least it's holding up for now.
I just hooked the jug up to the pump and let it run for about 5 minutes at various RPMs
September 14, 2007, 09:34:08 pm
blkboostedtruck
1.6 TD pump $70
September 14, 2007, 09:34:08 pm »
well Tyler I tried your trick tonite! ran 2quarts of ATF through it seemed to slow the leak down alot! i'll let it sit all weekend! since i gotta work on sunday! and i will see if it works on monday! I'm hopen to have a paypal sent to you by next friday for the other stuff! sorry it's taking so long but the holiday and short days are taking a toll on my paycheck!
thanks Duane
'66 variant 1500S
1.6 TD pump $70
