Author Topic: replacing wastegate  (Read 3062 times)
September 13, 2007, 11:20:19 am
gnavs
  • 340
replacing wastegate
« on: September 13, 2007, 11:20:19 am »
I'm trying to source a new wastegate for my newly acquired T3.  I've come across this place ( http://www.westcoast-turbo.com/wastegates.html )
although now i'm unsure as to which one, if any, will work.  the spring ratings both seem a bit low to me, but i'm pretty much a noob when it comes to turbo rebuilding.  :D
Reply #1September 13, 2007, 11:30:06 am
rallydiesel
  • 1880
replacing wastegate
« Reply #1 on: September 13, 2007, 11:30:06 am »
Make a boost controller for under $10 and it won't matter what the spring rate is.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2September 13, 2007, 11:47:51 am
replacing wastegate
« Reply #2 on: September 13, 2007, 11:47:51 am »
It looks to me like you'd need to do a whack of plumbing to get either of these two external gates to work.
A couple of other options might be:
1) try to find a T3 wastegate.... these guys appear to carry them:
http://www.gpopshop.com/turboparts.html
2) drive without a wastegate... actually very safe if you haven't dialed up the fuel, and especially if you have a boost gauge.
Reply #3September 13, 2007, 12:18:03 pm
gnavs
  • 340
replacing wastegate
« Reply #3 on: September 13, 2007, 12:18:03 pm »
so with a boost controller and wastegate, we'd be looking at something like this i'm assuming
without the wastegate would the controller just vent to atmosphere?
Reply #4November 13, 2007, 01:05:04 pm
gnavs
  • 340
replacing wastegate
« Reply #4 on: November 13, 2007, 01:05:04 pm »
http://www.treadstoneperformance.com/product.phtml?p=155&cat_key=50&prodname=T3+Turbo+Wastegate+Actuator+%26+Bracket
heres another I've found, but I am leaning towards no wastegate.  Would I simply plug the hole where the wastegate was or adapt a boost controller into it somehow?
Reply #5November 16, 2007, 12:28:37 pm
jauguston
  • 16
replacing wastegate
« Reply #5 on: November 16, 2007, 12:28:37 pm »
Rally Diesel,
Would you mind describing the $10.00 boost controller or provide a link to a build post.
Installed a '89 1.6TD into my '87 Suzuki Samurai. My design propane injection.
Reply #6November 16, 2007, 01:05:45 pm
gnavs
  • 340
replacing wastegate
« Reply #6 on: November 16, 2007, 01:05:45 pm »
this is the one i was going to make
http://www.geocities.com/chmwatson/FAQs/mbc.html
seems simple enough
Reply #7November 16, 2007, 01:13:32 pm
jauguston
  • 16
replacing wastegate
« Reply #7 on: November 16, 2007, 01:13:32 pm »
Thanks gnav, just what I was looking for.
Now if I could find a way to source the Lime Green advance spring for the pump I would be even happier.
