Author Topic: 1.6L: using NA pistons in a TD  (Read 4252 times)
February 18, 2005, 12:48:02 pm
Greasemonkey
  • 23
« on: February 18, 2005, 12:48:02 pm »
I have a set of first oversize pistons meant for the NA 1.6. I'd like to know if I can use them in a TD. I know the pistons are not notched for the cooler jets but that would be fairly easy to replicate using the old pistons as a pattern and then rebalance the set of pistons. Anybody ever try this?
91 Jetta
87 Scirocco 16v
http://www.vwot.org/~greasemonkey/
Reply #1February 19, 2005, 10:03:03 am
asau
« Reply #1 on: February 19, 2005, 10:03:03 am »
the n/a pistons won't take as much punishment as the turbo pistons
Reply #2February 20, 2005, 09:05:26 am
texas
  • 1
« Reply #2 on: February 20, 2005, 09:05:26 am »
My dad did this when turboing an old volvo diesel(eg. 6 cyl. 2.4l vw diesel). He made the notches in the pistons for the oil-squirters using a turbo-piston as reference.
The engine ran well 250kkm until it overheated due to a blown head-gasket.
Reply #3February 21, 2005, 09:46:49 pm
fspGTD
  • 1529
« Reply #3 on: February 21, 2005, 09:46:49 pm »
Quote from: "asau"
How specifically would a NA piston with a piston cooling clearance notch machined into be any different from a factory turbo piston?  Do you have evidence that the metallurgy is different?
Jake Russell
Reply #4February 23, 2005, 09:33:51 pm
« Reply #4 on: February 23, 2005, 09:33:51 pm »
if you look at http://members.rogers.com/harryfodder/  near the bottom
it shows you the changes to the pistons...  If you made the special notches in the pistons (did it right...) it should work.  But you would want to make sure that you use the turbo rings (unless they're the same with both N/A and diesel which i am not sure of)
Reply #5February 23, 2005, 09:48:10 pm
fspGTD
  • 1529
« Reply #5 on: February 23, 2005, 09:48:10 pm »
Quote from: "jtanguay"
According to ETKA, looking at the '83-'84 Rabbit parts listing, the piston rings are the same part for both 1.6lD naturally aspirated and turbo application.  IE: for 76.5mm diameter, the part number is 068 198 151 C.
Jake Russell
Reply #6February 24, 2005, 05:48:00 am
« Reply #6 on: February 24, 2005, 05:48:00 am »
very cool thanks for the info :)
