Author Topic: Just Bought A 1992 Jetta Diesel  (Read 9000 times)
August 28, 2007, 03:15:43 pm
Dieselrunner
  • 10
« on: August 28, 2007, 03:15:43 pm »
I just bought a1992 Jetta Turbo Diesel 1.6 L and i was wondering if there was somebody who is expierianced with tuning these engines.
I need to know what performance parts i can/should get.
Peace River, Alberta Canada
1992 VW Jetta Turbo Diesel 1.6 L
Reply #1August 29, 2007, 03:14:21 pm
« Reply #1 on: August 29, 2007, 03:14:21 pm »
try the IDI forums.  this is for TDI (direct injection)
Reply #2August 29, 2007, 06:58:31 pm
Infinitrium
  • 151
« Reply #2 on: August 29, 2007, 06:58:31 pm »
Quote from: "jtanguay"
        This is the idi forum, at least it was when i logged in
Reply #3August 29, 2007, 07:14:52 pm
Slave2School
  • 531
« Reply #3 on: August 29, 2007, 07:14:52 pm »
Quote from: "Infinitrium"
The post was probably moved to the proper location by admin lol
2002 ford focme wagon
Reply #4August 29, 2007, 07:52:32 pm
Black Smokin' Diesel
  • 656
« Reply #4 on: August 29, 2007, 07:52:32 pm »
Congrats on the new car! Check the vendor section for some ideas on performance parts then hit the tech forum.
Reply #5August 29, 2007, 08:04:05 pm
Dieselrunner
  • 10
« Reply #5 on: August 29, 2007, 08:04:05 pm »
alright thanx
i have pretty much zero knowledge of the diesel engines lol
Reply #6August 29, 2007, 08:17:11 pm
  • 656
« Reply #6 on: August 29, 2007, 08:17:11 pm »
Quote from: "Dieselrunner"
alright thanx
Then it's safe to say you're in the right place to learn about them :)
Reply #7August 29, 2007, 08:21:31 pm
Dieselrunner
  • 10
« Reply #7 on: August 29, 2007, 08:21:31 pm »
that is good lol i seen a car like mine in town
lowered, rims it looked really nice
im hoping that ill be able to race mine
right now it tops at 163 K/PH  lol its kinda sad
Reply #8August 29, 2007, 09:35:35 pm
Reply #9August 30, 2007, 01:22:33 pm
« Reply #9 on: August 30, 2007, 01:22:33 pm »
163kph isn't quite sad...  if speed is what you're after, you will need to either upgrade the 5th gear, or a whole new tranny itself.  you will notice that your car burns oil going at those speeds, so don't forget to check oil regularly.  the harder you drive it, the more oil it burns.  smooth acceleration and better fuel economy & very low oil consumption if any.  those are the rules of the diesel.  turbo warmup = 1-2 mins of ginger driving.  turbo cooldown - depends on how hot of a day, and how hard and long the car was run.  regular dino oil sitting in a super heated turbo will start to 'coke' inside the hot turbo, and the next time you start your car, nice little bits of rock hard deposits will be sent into oil.  synthetic oil really helps in this area, greatly reducing the risk (if any) of oil coking from the turbo.
good luck with the diesel!  don't forget to run an additive for lubricity, anti gelling, and cetane boost.  it will greatly increase your winter starting capability.
Reply #10August 31, 2007, 11:54:44 pm
Dieselrunner
  • 10
« Reply #10 on: August 31, 2007, 11:54:44 pm »
oh ya i was suprised at how smooth it was riding
usually hittin that speed youll be bouncing around on the road a bit
i wasnt bouncing at all
im hoping to upgrade the car all round(accel, top speed, milage, handling etc)
ok ill use thoses things from now on thanx for the tip
so what are a few things i should be looking for, for my engine (upgrades)
Better quality turbo, downpipes, exhaust what else is there to get?
Reply #11September 01, 2007, 11:28:57 am
« Reply #11 on: September 01, 2007, 11:28:57 am »
- Giles pump (your pump will probably leak soon anyways if it has never been rebuilt) check out vendor section for his threads.
- larger downpipe (see PassengerPerformance - 935racer)
- intercooler (any is better than none, but piping, and location is pretty crucial.  if you can't get rid of the heat, it will be doing more bad than good!)
get those three things, and you won't be dissapointed!  i'd imagine if your car doesn't burn much oil going 160kph then your motor is pretty good and solid.  just make sure to run a good synthetic oil AND FILTER (NO FRAM!!!) and you will help keep it that way for quite a while.
new suspension (heavy duty struts & shocks and lowering springs) will greatly enhance driveability.  mine is a pretty bumpy ride, but it handles quite well.  ball joints changed, and new tie rods are next (i've opted for the whole tie rod... who knows what kind of damage the old ones have?)
one thing i recommend that i dont think anyone does, is to bleed the brake system.  i just had a run in with a leaking wheel cylinder in the rear... not cool!!! flushing out the old fluid with new fluid (at the time i bought the car...) might have bought me an extra couple of years.. or more?  the shoes still had plenty of meat on them too... but soaked in brake fluid... a shame indeed!  the other side was toast though... the pad on one side had actually fell a little bit down the shoe.  i'm surprised it didn't fall off  :shock:.
little maintenance things like lubricating the shifter linkage etc is a great idea.  i had my car undercoated from Rust Check (that cool rust proofing stuff) and amazingly afterwards my shifter was very loose and lubricated!  i could have done it myself, but i thought i would need to buy a new linkage kit to solve the 'sticky' shifter issue.
try to read up some archived posts about little maintenance tips.  draining the water separator, coolant flushes, bushings etc...
whereabouts are you located? should put that in your profile  :wink:
Reply #12September 02, 2007, 09:23:32 pm
Dieselrunner
  • 10
« Reply #12 on: September 02, 2007, 09:23:32 pm »
whats a Giles Pump?   whats it do?  and what do you mean by threads? lol told ya im not very knowledgeable lol
what kind of filter should i use if not a fram?
after i get my lowering kit and new struts etc im gonna be redoing the ball joints and all that getting a lil stronger ones just incase
ya i need to bleed mine again, i did it when i replaced the brakes but they still dont work right   luckily i have the tranny to slow me down lol
so you would recomend i get that rust proof stuff? what would it cost me?
im in Peace River Alberta, i prolly should put that eh lol
Reply #13September 03, 2007, 12:27:15 pm
« Reply #13 on: September 03, 2007, 12:27:15 pm »
Giles is a Bosch pump Guru who has developped his own unique mods to our diesel pumps.  Better performance and fuel economy is what it's all about.  after a few years it would more than pay for itself.
filters... try to at least get a Bosch.  Mann filters are good.  (the new bosch aren't made in Germany AFAIK)
if your brakes aren't working, it could be the vacuum assist, or a bunch of other problems associated with the rear brakes.
i would recommend that you rust proof the car with rust check to 'loosen' up stuff.  they lube the car up pretty good.  it's just a good idea to do it.  or at the very least, lube up your shifter linkage.  smoother and faster shifting rules!!!
Reply #14September 04, 2007, 07:29:53 pm
Dieselrunner
  • 10
« Reply #14 on: September 04, 2007, 07:29:53 pm »
oh ok so where can i get a Giles Pump?
im liking the effects of it (better performace and fuel economy)
as it is my car gets like 53 MPG
ok i know i could get bosch filters so ill get one of them
i definatly need to bleed the rear brakes again it wasnt done right when my dad did it
i know a guy who can make me fiberglass bodykits so i think i might do that, im going to get him to shave my doors too  8)  i hate the look of the black trim so im gonna get him to remove the trim and even out the ridge where the trim is i think ill keep the handles though
so what exactly is the rust proof is it like a paint they spray on or what?
