Fixmyvw.com
Author Topic: EGT Gauge  (Read 3707 times)
August 21, 2007, 04:16:31 pm
nogama3
  • 162
EGT Gauge
« on: August 21, 2007, 04:16:31 pm »
guys, where is this atached and any pics of yours please.
also, what should i be looking for after fitting one of these?
what are the benefits?
any info appreciated.
Reply #1August 21, 2007, 04:47:23 pm
Benjamin
  • 485
EGT Gauge
« Reply #1 on: August 21, 2007, 04:47:23 pm »
on my manual they say you need to install on a place where all the tubes camed toghether, so you measure the temperature from 4cilinders toghether. But if you have an external wastegate, where to measure?
Same for the EMP (exhaust manifold pressure), where to place, before or after external wastegate?
Greetz, Benjamin
Must make +250hp
Reply #2August 22, 2007, 10:39:14 pm
flapjack
  • 283
EGT Gauge
« Reply #2 on: August 22, 2007, 10:39:14 pm »
this post is awesome:
http://www.vwdiesel.net/phpBB/viewtopic.php?t=1352
second page is the egt install with pictures
another one
http://vwdiesel.net/phpBB/viewtopic.php?t=1528&highlight=egt
signature
Reply #3August 23, 2007, 05:28:03 am
nogama3
  • 162
EGT Gauge
« Reply #3 on: August 23, 2007, 05:28:03 am »
thanks, very interesting threads
Reply #4August 23, 2007, 11:22:37 am
EGT Gauge
« Reply #4 on: August 23, 2007, 11:22:37 am »
Here is something I was considering, if we know that the #4 cyl is the most challenged when it comes to airflow and coolant temps maybe we should have the probe mounted closer to that cyl.
monitoring the hottest cyl would be safer than the sum off all four at the turbo inlet.
Fixmyvw.com
