aaz crank
Pages:
Topic: aaz crank (Read 12104 times)
Reply #15
February 22, 2005, 10:01:14 am
dieselweasel
aaz crank
Reply #15 on:
February 22, 2005, 10:01:14 am »
Either the damper isn't seated properly all the way around or it's warped. Definitely NOT supposed to be like this. You'll want to replace it as soon as possible.
Reply #16
February 22, 2005, 11:23:26 am
asau
aaz crank
Reply #16 on:
February 22, 2005, 11:23:26 am »
cool thats what i wanted to hear
Reply #17
March 25, 2005, 12:36:50 pm
timing gear
Reply #17 on:
March 25, 2005, 12:36:50 pm »
I ordered a TDI crank timing gear with flat, from Jack, using the number given (028 105 263E ) and ended up with the old style timing gear.
Are you sure that's the right number?
What's the number for the old lame little key timing gear?
Reply #18
March 25, 2005, 01:16:43 pm
QuickTD
aaz crank
Reply #18 on:
March 25, 2005, 01:16:43 pm »
I rechecked the part number and I was wrong, I apologize. I must have assumed that the the higher the letter suffix, the newer the gear. This is not the case. The TDI gear is 028 105 263D. I have edited my previous post to correct the error. Again, I apologize.
Reply #19
March 25, 2005, 10:19:35 pm
timing gear
Reply #19 on:
March 25, 2005, 10:19:35 pm »
No problem, I'll use it on a NA diesel and it'll be awhile before I have the crank out.
Thanks for finding the right number.
Pages:
aaz crank
