Author Topic: Thought I´d share some pics of my ride.  (Read 2437 times)
August 14, 2007, 11:42:47 am
Sierra94
  • 123
    Dieselsmoke in every stroke... M-Tdi Mazda!!
    • http://www.garaget.org/sierra94
« on: August 14, 2007, 11:42:47 am »
Here she is. A 1999 VW Caddy 1.9 D, slightly uprated with a KKK24 turbo and 12 mm rotor head, modified aneroid pin etc  :twisted:
It delivers 2.2 bars of boost at a EGT of maximum 800 degrees celsius. It has a 0-60 mph speed of 6 seconds. So I guess it runs fairly nice  :lol:
A pic of the installed clutch:
A pic of the soon to be installed intercooler:
And the soon to be installed frontend:
And a pic of the brakes I´m currently installing, 4 piston Brembo calipers with Seat Ibiza Cupra turbo rotors, diameter 280 mm.
And 2 pics of the turbo install, it´s a KKK24 and 2.5 inch downpipe etc:
<-- My M-tdi Mazda B-1800 and my other cars
Reply #1August 14, 2007, 04:47:01 pm
Dr. Diesel
  • 1341
« Reply #1 on: August 14, 2007, 04:47:01 pm »
the new version of what we used to get here. Pretty neat!
Funny how your dipstick goes to the back of the block...
Get a nice intercooler in there and cool air to the filter, then you'll really be rocking!
nice job!
Reply #2August 14, 2007, 05:33:56 pm
« Reply #2 on: August 14, 2007, 05:33:56 pm »
That looks great, that IC should make a nice difference
Reply #3August 14, 2007, 10:01:09 pm
OM617
« Reply #3 on: August 14, 2007, 10:01:09 pm »
You are going to have major cracking issues with that welded flange unless to took the correct steps to heat the manifold before welding.
Non-dampened clutches are horrible if you want to use it as anything but a race-only car.
Reply #4August 15, 2007, 01:46:53 am
Sierra94
  • 123
« Reply #4 on: August 15, 2007, 01:46:53 am »
It´s not welded to the manifold. It´s a custom made "Bolt in" adapter made of 2 thick plates and a thick tube from the square flange on the manifold to the trapezoid shaped one on the turbo.
Reply #5August 15, 2007, 06:56:10 am
« Reply #5 on: August 15, 2007, 06:56:10 am »
Looks sweet!!
What did you use to make your down pipe?
