Author Topic: GTD Rev counter not working  (Read 5960 times)
Reply #15December 01, 2008, 08:54:30 am
arb
« Reply #15 on: December 01, 2008, 08:54:30 am »
Quote from: "numbnuts"
Thanks alot, i am about to solder it when it stops raining :roll:
The thing about soldering on anything that viborates is you must strain relief the wire after the connection or the wire will crack at the edge of the solder joint. That is why on cars nearly all wires are crimped - the crimp is the strain relief. Yes, solder is a better connection electrically, but imobilze the wire right after the solder if you want it to last.
Reply #16December 01, 2008, 09:59:13 am
regcheeseman
  • 714
« Reply #16 on: December 01, 2008, 09:59:13 am »
anyone know about this??? cheers
Yeah, a little bit  :lol:  what revcounter are you running? Have you looked at my revcounter thread in the FAQ section?
Reply #17December 01, 2008, 01:13:39 pm
Jimmy Diesel Junior
  • 64
« Reply #17 on: December 01, 2008, 01:13:39 pm »
Hello and thanks for your reply. I haven't looked at the FAQ but i will now. I'm using vw jetta turbo diesel clocks. Any ideas why it's not working or what i can check for.
PEACE THROUGH SUPERIOR HORSE POWER
Reply #18December 02, 2008, 04:13:07 am
regcheeseman
  • 714
« Reply #18 on: December 02, 2008, 04:13:07 am »
hi all i fitted vw taco into my mk2 but they're not working. If i have a w-terminal on my alternator, how do i connect this to my taco to get it working?????
You need a connection between altenator w terminal and revcounter for it to work.
Whatever your mk2 is, if it was a gasser, find the revcounter signal wire that was original connected to dizzy/ignition coil and run it down to the alt w term - that should sort it.
Reply #19December 02, 2008, 10:47:58 am
Jimmy Diesel Junior
  • 64
« Reply #19 on: December 02, 2008, 10:47:58 am »
Hello. The rev counter is from a td jetta and my car is a gtd golf so all diesel. So i need to connect the w terminal wire to the clocks is that right?? I know where the w terminal is but where do i connect it to the clocks?? Do i need to splice it into the plug that goes to the clocks?? If so which wire is it?? Cheers for the help..shane
Reply #20December 02, 2008, 11:50:38 am
« Reply #20 on: December 02, 2008, 11:50:38 am »
Quote from: "Jimmy Diesel Junior"
The wire is already there Shane.
Should be part of the Alt harness from the engine all the way to the cluster.
Reply #21December 02, 2008, 11:34:25 pm
Jimmy Diesel Junior
  • 64
« Reply #21 on: December 02, 2008, 11:34:25 pm »
Sound, I'll go hunting for it tonight :-) I'll keep posted
Reply #22December 27, 2008, 07:25:47 am
Jimmy Diesel Junior
  • 64
« Reply #22 on: December 27, 2008, 07:25:47 am »
Hi all. Just an update. The wire was actually not there at all. i brought a wire from the W-Terminal (green wire) to plug G1 pin 12 in the fuse box and Voila. Thanks for all the help gents..Shane
