Author Topic: Would this engine cover fit on my 93 TD IDI?  (Read 4447 times)
July 28, 2007, 06:01:36 pm
Reply #1July 28, 2007, 06:29:16 pm
gnavs
  • 340
« Reply #1 on: July 28, 2007, 06:29:16 pm »
sweet
Reply #2July 28, 2007, 07:21:00 pm
« Reply #2 on: July 28, 2007, 07:21:00 pm »
What's a zl?
Reply #3July 28, 2007, 08:06:08 pm
Black Smokin' Diesel
  • 656
« Reply #3 on: July 28, 2007, 08:06:08 pm »
Quote from: "burn_your_money"
What's a zl?
Nooo idea but I doubt that cover will fit.
91 Passat syncro 1.8T swapped.
Reply #4July 29, 2007, 10:42:20 am
Mk2Fanatic
  • 93
« Reply #4 on: July 29, 2007, 10:42:20 am »
that'll only fit a TDI or SDI 1.9 with the 3 bolt mounting pattern (like the B4 Passat TDI or the 98-99 1z TDI)
5 VW's: Mojave beige (LE1N) Mk1 rabbit 16V; Mk2 Jetta wolfsburg TDI conversion;Mk2 1.6TD Twin Charged Project; 86Mk2 1.6TD Jetta (daily); 1988 1.6NA Jetta; 1994 Passat 1.9TD donor
Reply #5July 29, 2007, 12:36:45 pm
« Reply #5 on: July 29, 2007, 12:36:45 pm »
i could see it fit.  but you will need to cut & modify certain things... probably end up butchering it a little...  anything is possible with time & money  :wink:
Reply #6July 31, 2007, 03:50:32 am
Ziptar
  • 565
« Reply #6 on: July 31, 2007, 03:50:32 am »
I hate those covers... The one that came on my 2003 didn't last the year along with the belly pan.
Engines must be seen, not hidden!
Reply #7July 31, 2007, 06:23:18 am
compu_85
  • 24
    • http://compu85.homeip.net
« Reply #7 on: July 31, 2007, 06:23:18 am »
Do replace the lower cover though... it keeps water out of the turbo's VNT actuator. At least up here, moisture sitting in there will rust it out.
-Jason
99.5 Jetta GLS TDI. 219k miles
91 Jetta GL ECOdiesel. 400k miles+ Sold.
91 Mercedes 350SDL. 202k miles.
Reply #8August 01, 2007, 03:47:11 am
Ziptar
  • 565
« Reply #8 on: August 01, 2007, 03:47:11 am »
I just rolled past 208,000 miles yesterday, you might be right about significantly reducing the lifespan of my engine. :D
Actually I live in Florida, I think in the almost 5 years I have had my 2003 it got cold enough for the glow plugs to come on once.
Warm up time is very short without the covers in these parts.
